I’m new to Salome. I tried to get Shaper project and build it in Window 11. It sounds to me that I should be able to do it by run “build_Salome_rel.bat” or “build_Salome_deb.bat”. However, neither of them worked.
Then I took a quick look at “build_Salome_rel.bat”: @ECHO OFF
REM Find absolute path to ROOT_DIR @SET PARENT_DIR=%~dp0… @SET ROOT_DIR=
pushd %PARENT_DIR% @SET ROOT_DIR=%CD%
popd
@SET SRC_DIR=%ROOT_DIR%\sources
call %SRC_DIR%\env_Salome.bat
Basically I could not find the “sources” folder in Salome, neither “env_Salome.bat”.
Did I miss anything? In order to setup the development environment for the shaper project, what else need to be downloaded?
Nabil, Thank you very much for your information. I could proceed these steps successfully until the last one. I failed to compile shaper with following error message:
D:\Salome>SALOME-9.9.0\W64\Python\python.exe SAT\sat compile SALOME-9.9.0 -p SHAPER,CONFIGURATION --clean_all
Executing the compile commands in the build directories of the products of the application SALOME-9.9.0
SOURCE directory = D:\Salome\SALOME-9.9.0\SOURCES
BUILD directory = D:\Salome\SALOME-9.9.0\BUILD
Compilation of CONFIGURATION … ignored
Compilation of SHAPER … ERROR : the following mandatory product(s) is(are) not installed: Sphinx
It sounds like that Sphinx is not installed. Should I install it previously?
