I am new to Salome and trying to run Salome 9.13.0 on Ubuntu 22.04 as a virtual machine on M1 Mac UTM.
There were 2 problems.
- After following the steps in README, I am left with one missing package: libquadmath0. The thing is, there does not seem to be a version for ARM architecture.
ubuntu@ubuntu:~/Documents/salome-9.13.0$ sudo apt install libquadmath0
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package libquadmath0
ubuntu@ubuntu:~/Documents/salome-9.13.0$ apt list | grep libquadmath0
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libquadmath0-amd64-cross/jammy-updates,jammy-security 12.3.0-1ubuntu1~22.04cross1 all
libquadmath0-i386-cross/jammy-updates,jammy-security 12.3.0-1ubuntu1~22.04cross1 all
libquadmath0-ppc64el-cross/jammy-updates,jammy-security 12.3.0-1ubuntu1~22.04cross1 all
libquadmath0-x32-cross/jammy-updates,jammy-security 12.3.0-1ubuntu1~22.04cross1 all
- When I tried to run
./salomeor./mesa_salome, there is this message.
File "/home/ubuntu/Documents/salome-9.13.0/BINARIES-UB22.04/SALOME/bin/salome/salomeContext.py", line 325, in _startSalome
File "/home/ubuntu/Documents/salome-9.13.0/BINARIES-UB22.04/SALOME/bin/salome/salomeContext.py", line 413, in _sessionless
setenv.main(True, exeName="salome withsession")
File "/home/ubuntu/Documents/salome-9.13.0/BINARIES-UB22.04/KERNEL/bin/salome/setenv.py", line 238, in main
args, modules_list, modules_root_dir = get_config(silent=silent, exeName=exeName, keepEnvironment=keep_env)
File "/home/ubuntu/Documents/salome-9.13.0/BINARIES-UB22.04/KERNEL/bin/salome/setenv.py", line 85, in get_config
args = launchConfigureParser.get_env(exeName=exeName, keepEnvironment=keepEnvironment)
File "/home/ubuntu/Documents/salome-9.13.0/BINARIES-UB22.04/KERNEL/bin/salome/launchConfigureParser.py", line 954, in get_env
if verbose(): print("Configure parser: Warning : can not find configuration file %s" % filename)
File "/home/ubuntu/Documents/salome-9.13.0/BINARIES-UB22.04/KERNEL/bin/salome/salome_utils.py", line 458, in verbose
import KernelBasis
File "/home/ubuntu/Documents/salome-9.13.0/BINARIES-UB22.04/KERNEL/bin/salome/KernelBasis.py", line 15, in <module>
import _KernelBasis
ImportError: /home/ubuntu/Documents/salome-9.13.0/BINARIES-UB22.04/KERNEL/lib/salome/_KernelBasis.so: cannot open shared object file: No such file or directory
There is a similar topic with an older Salome version here, but not very sure how the author made it work.
