How to Set Boundary Conditions
I want to perform an analysis to check the stress that occurs when a steel bar (10 mm × 10 mm × 100 mm) with both ends fixed is cooled from 30°C to -50°C. However, even though I believe I have fixed both ends, when I view the displacement using “Warp by Vector” of ParaViS, the bar appears to shift in position and deform abnormally. If anyone knows the cause, please let me know. I’m a beginner, so I would really appreciate a clear and detailed explanation.Incidentally, I use the windows version of Salome Meca 9.10.0.
Reference.pdf (200.3 KB)
recommend you to post in salome meca forum as it is specific to it Code_Aster
Thank you for your advice. I’ll post in salome meca forum
