I’m currently attempting to compile the HELLO.dll and HELLOEngine.dll from the source code available in the Git repository. It appears that the CMake files provided for both HELLO and HELLOGUI are configured for generating static libraries (.lib) with the following commands:
Could you confirm if this is the intended setup? Additionally, I’m wondering if there are separate CMake files available specifically for building .dll files.
I appreciate your prompt response. I’ve successfully generated the SalomeHELLO.sln for Visual Studio and built the solution. However, I seem to be missing the .dll files. Could you please verify this? I’ve attached further details for your reference. salome_forum_1.pdf (280.5 KB)
I successfully followed the attached instructions until the step where it prompted to clone the HELLO and CONFIGURATION. Please see attached error message. The issue derives from the presence of a ‘rm’ command, designed for Linux systems, while I am operating on Windows. Is there a script available that I can adjust to use ‘rmdir’ for Windows?
I extracted the HELLO and CONFIGURATION source manually into the SALAME-9.12.0\W64 folder, followed by executing the compilation command. Here’s the resulting output.
cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_GENERATOR=“Visual Studio 15 2017 Win64” -DCMAKE_INSTALL_PREFIX=C:\S\SALOME-9.12.0\W64\HELLO C:\S\SALOME-9.12.0\SOURCES\HELLO
CMake Warning:
Ignoring extra path from command line:
“C:\S\SALOME-9.12.0\SOURCES\HELLO”
CMake Error: The source directory “C:/S/SALOME-9.12.0/SOURCES/HELLO” does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
CMake Deprecation Warning at CMakeLists.txt:19 (CMAKE_MINIMUM_REQUIRED):
Compatibility with CMake < 2.8.12 will be removed from a future version of
CMake.
Update the VERSION argument value or use a … suffix to tell
CMake that the project does not need compatibility with older versions.
CMake Error at CMakeLists.txt:24 (PROJECT):
Generator
could not find any instance of Visual Studio.
– Configuring incomplete, errors occurred!
See also “C:/S/SALOME-9.12.0/BUILD/HELLO/CMakeFiles/CMakeOutput.log”.
I am using Visual Studio 2022 and I am setting the cmake generator and here is the error.
PS C:\S> cmake -G “Visual Studio 17 2022” C:\S\SALOME-9.12.0\SOURCES\HELLO
Compatibility with CMake < 3.5 will be removed from a future version of
CMake.
– Selecting Windows SDK version 10.0.22621.0 to target Windows 6.2.9200.
CMake Error at CMakeLists.txt:35 (MESSAGE):
We absolutely need the Salome CMake configuration files, please define
CONFIGURATION_ROOT_DIR !
Here you’re trying to compile by command line.
If you use SAT, edit SALOME-9.12.0(windows).pyconf and fix the cmake generator.
If you aim to do it wirhout SAT, then you need to setup SALOME environment by running call env_launch.bat first.
I tried to do it without SAT so I run env_launch.bat then
PS C:\S> SALOME-9.12.0\W64\Python\python.exe SAT\sat compile SALOME-9.12.0 -p HELLO,CONFIGURATION --clean_all
go to the directory in which SALOME-9.12.0 was extracted, then run (and be patient): call SALOMEConfigTool.bat --application SALOME-9.12.0 --use-gitpub --products CONFIGURATION,HELLO
This command will:
clone SAT and SAT_SALOME
patch SAT_SALOME to remove some non public products
target gitpub repositories and clone CONFIGURATION and HELLO products
set up visual 2017 by running: call "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvarsall.bat" x64
You can then check that CONFIGURATION and HELLO are in directory SALOME-9.12.0\SOURCES
Thank you for the detail instructions. I followed your instructions to set it up but I am not getting the same result. Do you know why?
Here is the result I got.
