The archive ‘ARCHIVES/ParaView-5.11.0.tar.gz’ cannot be decompressed due to a file name that is too long :
archive_extract: [Errno 36] File name too long: ‘/home/serge/salome/SALOME-9.14.0-native-UB24.04/SOURCES/ParaView/Testing/Data/HTGMulti/.ExternalData_SHA512_977df95fb64e0fd8c22d02966cd5ac452dd5cb4fca0cf74f00989079a6125e136c4f29d2680c31a26cbffdf4f96562d45ca6320a83b2b9a052703716a5a7d7e8’
could not reproduce this on my side. you can still do:
cd ARCHIVES
gunzip ParaView-5.11.0.tar.gz
tar --delete -f ParaView-5.11.0.tar ParaView/Testing/Data/HTGMulti/.ExternalData_SHA512_977df95fb64e0fd8c22d02966cd5ac452dd5cb4fca0cf74f00989079a6125e136c4f29d2680c31a26cbffdf4f96562d45ca6320a83b2b9a052703716a5a7d7e8
gzip ParaView-5.11.0.tar
Then, with SAT, run:
sat/sat prepare SALOME-9.14.0-native -p ParaView
or
sat/sat -o "APPLICATION.properties.git_server='github'" prepare SALOME-9.14.0-native -c
one would need to check if ParaView builds fine. Let us know. thanks
I sent the command:
SAT/sat -o “APPLICATION.properties.git_server=‘github’” compiles SALOME-9.14.0-native --clean_all
ParaView unpacking is done correctly. But now I have errors on:
Compilation of open turns … KO
Compilation of poetry_core … ERROR: the following mandatory product(s) is(are) not installed: openturns
Compilation of poetry … ERROR: the following mandatory product(s) is(are) not installed: openturns poetry_core
Compilation of BasicIterativeStatistics … ERROR: the following mandatory product(s) is(are) not installed: openturns poetry_core poetry
I see. Can you ensure that you do have all system prerequisites, mentioned in this thread:
In addition, note that, as it is discussed here, you can view the log files for each product in directory: SALOME-9.14.0-native-UB24.04/LOGS/.
I have correct dependencies :
SAT/sat config SALOME-9.14.0-native --check_system
Check the system dependencies declared in the application
- python3-babel : OK
- python3-pytest-cython : OK
- python3-jinja2 : OK
- python3-pil : OK
- python3-pyqt5 : OK
- python3-pyqt5.qtsvg : OK
- pyqt5-dev : OK
- pyqt5-dev-tools : OK
- python3-pygments : OK
- python3-sphinx : OK
- python3-alabaster : OK
- libboost-all-dev : OK
- python3-certifi : OK
- python3-cftime : OK
- python3-chardet : OK
- python3-click : OK
- cmake : OK
- libcminpack1 : OK
- libcminpack-dev : OK
- libcppunit-dev : OK
- python3-cycler : OK
- python3-dateutil : OK
- python3-docutils : OK
- doxygen : OK
- libeigen3-dev : OK
- fftw : OK
- fftw-dev : OK
- libfreeimage3 : OK
- libfreeimage-dev : OK
- graphviz : OK
- libgraphviz-dev : OK
- python3-h5py : OK
- python3-idna : OK
- python3-imagesize : OK
- python3-kiwisolver : OK
- liblapack3 : OK
- liblapacke : OK
- liblapack-dev : OK
- liblapacke-dev : OK
- libxml2 : OK
- libxml2-dev : OK
- clang : OK
- llvm-dev : OK
- python3-markdown-it : OK
- python3-markupsafe : OK
- python3-matplotlib : OK
- python3-mdurl : OK
- libmetis5 : OK
- libmetis-dev : OK
- python3-mpi4py : OK
- python3-netcdf4 : OK
- libnlopt0 : OK
- libnlopt-cxx0 : OK
- python3-nlopt : OK
- libnlopt-dev : OK
- libnlopt-cxx-dev : OK
- python3-nose : OK
- python3-numpy : OK
- python3-numpydoc : OK
- python3-packaging : OK
- python3-pandas : OK
- python3-patsy : OK
- python3-psutil : OK
- python3-pyparsing : OK
- readline-common : OK
- python3-pytest : OK
- python3-tz : OK
- python3-yaml : OK
- libqwt-qt5-6 : OK
- libqwt-qt5-dev : OK
- python3-requests : OK
- python3-rich : OK
- libbsd0 : OK
- libbz2-1.0 : OK
- libc6 : OK
- libdrm2 : OK
- libegl1 : OK
- libexif12 : OK
- libexpat1 : OK
- libfftw3-double3 : OK
- libfontconfig1 : OK
- libgl1 : OK
- libglu1-mesa : OK
- libgomp1 : OK
- libgphoto2-6 : OK
- libice6 : OK
- libjbig0 : OK
- libltdl7 : OK
- liblzma5 : OK
- libnuma1 : OK
- libpcre3 : OK
- libquadmath0 : OK
- libraw1394-11 : OK
- libsm6 : OK
- libstdc++6 : OK
- libtiff5 : OK
- libudev1 : OK
- libusb-1.0-0 : OK
- libuuid1 : OK
- libx11-6 : OK
- libx11-xcb1 : OK
- libxau6 : OK
- libxcb1 : OK
- libxcb-glx0 : OK
- libxcb-xfixes0 : OK
- libxcb-xkb1 : OK
- libxdmcp6 : OK
- libxext6 : OK
- libxft2 : OK
- libxi6 : OK
- libxkbcommon0 : OK
- libxkbcommon-x11-0 : OK
- libxmu6 : OK
- libxpm4 : OK
- libxrender1 : OK
- libxss1 : OK
- libxt6 : OK
- zlib1g : OK
- libsqlite3 : OK
- libdc1394-25 : OK
- libopenexr-3-1-30 : OK
- libwebp7 : OK
- gfortran-13 : OK
- libevent-2.1-7 : OK
- libpng16-16 : OK
- libgcc-13-dev : OK
- libncurses6 : OK
- libffi8 : OK
- libtinfo6 : OK
- libgphoto2-port12 : OK
- libglx0 : OK
- libopengl0 : OK
- libzstd1 : OK
- libglvnd0 : OK
- openmpi-bin : OK
- libgdal34t64 : OK
- libopenblas0-serial : OK
- libtbb12 : OK
- libxml++2.6-2v5 : OK
- libfreetype6 : OK
- libssl-dev : OK
- gcc : OK
- make : OK
- sed : OK
- g++ : OK
- libexpat1-dev : OK
- libfontconfig1-dev : OK
- flex : OK
- bison : OK
- libglu1-mesa-dev : OK
- perl : OK
- libxcb-dri2-0-dev : OK
- libxkbcommon-dev : OK
- libxkbcommon-x11-dev : OK
- bzip2 : OK
- libxi-dev : OK
- libxt-dev : OK
- libxmu-dev : OK
- libxpm-dev : OK
- libxft-dev : OK
- automake : OK
- libtool : OK
- libjpeg-dev : OK
- cmake : OK
- libicu-dev : OK
- libopenmpi-dev : OK
- libreadline-dev : OK
- libhwloc-dev : OK
- libsqlite3-dev : OK
- libcurl4-openssl-dev : OK
- libxcursor-dev : OK
- libtbb-dev : OK
- cython3 : OK
- libfftw3-dev : OK
- libopenblas-dev : OK
- qttools5-dev : OK
- libqt5svg5-dev : OK
- libqt5x11extras5-dev : OK
- qtxmlpatterns5-dev-tools : OK
- libpng-dev : OK
- libtiff5-dev : OK
- libgeotiff-dev : OK
- libgif-dev : OK
- libgeos-dev : OK
- libgdal-dev : OK
- dvipng : OK
- libxml++2.6-dev : OK
- libfreetype-dev : OK
- libgmp-dev : OK
- libmpfr-dev : OK
- libxinerama-dev : OK
- python3-scipy : OK
- python3-setuptools : OK
- python3-sip : OK
- python3-sip-dev : OK
- python3-six : OK
- python3-stemmer : OK
- python3-sphinx-rtd-theme : OK
- python3-sphinxcontrib.websupport : OK
- sphinx-intl : OK
- python3-statsmodels : OK
- libtcl : OK
- tcl-dev : OK
- libtk : OK
- tk-dev : OK
- python3-toml : OK
- python3-urllib3 : OK
either install prerequisites I mentioned or share the Log files.
Here the logs of openturn.
script.log (514.2 KB)
At first glance in the shared log file, it seems you’re missing fftw. Install: fftw-dev libfftw3-dev and libfftw3-bin via apt tool, then run:
SAT/sat compile SALOME-9.14.0-native -p openturns --clean_all
to check that it compiles well. Let us know if this helps.
Note that you can also edit the compilation script and switch off this Openturns module. But better install the prerequisite.
Now it’s Paraview that doesn’t compile. Here’s the log.
script.log (78.2 KB)
Please, ensure that system prerequisites mentioned in this thread and its attached file :
are installed and compile again. If it still does not compile share your CMakeCache.txt file as well as the log file. CMakeCache.txt file can be found in BUILD/Paraview directory.
Here the error points to either qtxmlpattern not installed or several installations.
script.log (1.5 MB)
CMakeCache.txt (254.1 KB)
I still can’t get ParaView to compile. ![]()
Did you install all prerequisites listed in file ub24-system.txt ?
Here, the comparison of the two CMakeCache.txt files shows that libx11-xcb-dev libx11-xcb1 libxtst-dev libxtst6 libxcb-render0-dev libxcb-render0 libxcb-shape0-dev libxcb-shape0 libxcb-shm0-dev libxcb-shm0 libxcb-xfixes0-dev libxcb-xfixes0 are not installed.
Install these packages and if it still fails, share again CMakeCache.txt file, log file and UB24.txt, output of: apt list --installed &> UB24.txt
regards.
You have a CMake error in the output file at line 496.
Failed to convert servermanager XML: xmlpatterns: could not find a Qt installation of ‘’
I see that, supposedly, you have the required qt packages installed.
I suggest removing the ParaView build directory and try building it again.
yes, ensure that you run:
SAT/sat -o "APPLICATION.properties.git_server='github'" compile SALOME-9.14.0-native -p ParaView --clean_all
if it does not work, share mentioned files. if it works, then resume compilation with:
# clean BUILD directory
rm -rf SALOME-9.14.0-native-UB24.04/BUILD
# resume compilation
script.log (1.5 MB)
Unfortunately this doesn’t work !
Here is the result of : list --installed &> UB24.txt
UB24.txt (220.5 KB)
I can see that you’re still missing some additional packages. Please install them with apt tool and let us know if it still fails …
ub24-additional-packages.txt (1.6 KB)
I have error messages when installing the python3-future package.
Is this package essential:
sudo apt reinstall python3-future
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 342 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 fr.archive.ubuntu.com / ubuntu.lafibre.info noble/universe amd64 python3-future all 0.18.2-6ubuntu2 [342 kB]
Fetched 342 kB in 5s (65,2 kB/s)
(Legado de datumbazo … 404915 dosieroj kaj dosierujoj aktuale instalitaj.)
Preparado por anstataŭigi …/python3-future_0.18.2-6ubuntu2_all.deb …
Elpakado de python3-future (0.18.2-6ubuntu2) sur (0.18.2-6ubuntu2) …
Ni alĝustigas python3-future (0.18.2-6ubuntu2) …
/usr/lib/python3/dist-packages/future/backports/email/_header_value_parser.py:662: SyntaxWarning: invalid escape sequence ‘(’
‘(’, ‘(’).replace(
/usr/lib/python3/dist-packages/future/backports/email/_header_value_parser.py:663: SyntaxWarning: invalid escape sequence ‘)’
/usr/lib/python3/dist-packages/future/backports/email/_header_value_parser.py:1349: SyntaxWarning: invalid escape sequence ‘]’
‘’.join(ATOM_ENDS).replace(‘\’,‘\\’).replace(‘]’,‘]’))).match
/usr/lib/python3/dist-packages/future/backports/email/_header_value_parser.py:1352: SyntaxWarning: invalid escape sequence ‘]’
‘’.join(TOKEN_ENDS).replace(‘\’,‘\\’).replace(‘]’,‘]’))).match
/usr/lib/python3/dist-packages/future/backports/email/_header_value_parser.py:1354: SyntaxWarning: invalid escape sequence ‘]’
‘’.join(ATTRIBUTE_ENDS).replace(‘\’,‘\\’).replace(‘]’,‘]’))).match
/usr/lib/python3/dist-packages/future/backports/email/_header_value_parser.py:1357: SyntaxWarning: invalid escape sequence ‘]’
/usr/lib/python3/dist-packages/future/backports/email/header_value_parser.py:1541: SyntaxWarning: invalid escape sequence ‘\ ’
“”"ctext = <printable ascii except \ ( )>
/usr/lib/python3/dist-packages/future/backports/email/header_value_parser.py:1876: SyntaxWarning: invalid escape sequence ‘\ ’
“”" dtext = <printable ascii except \ [ ]> / obs-dtext
/usr/lib/python3/dist-packages/future/backports/email/feedparser.py:37: SyntaxWarning: invalid escape sequence ‘\Z’
NLCRE_eol = re.compile(’(\r\n|\r|\n)\Z’)
/usr/lib/python3/dist-packages/future/backports/email/utils.py:68: SyntaxWarning: invalid escape sequence ‘\A’
‘([^\ud800-\udbff]|\A)\udc00-\udfff’).search
/usr/lib/python3/dist-packages/future/backports/html/parser.py:31: SyntaxWarning: invalid escape sequence ‘\s’
tagfind = re.compile('([a-zA-Z][-.a-zA-Z0-9:])(?:\s|/(?!>))’)
/usr/lib/python3/dist-packages/future/backports/html/parser.py:79: SyntaxWarning: invalid escape sequence ‘\s’
endtagfind = re.compile('</\s*([a-zA-Z][-.a-zA-Z0-9:])\s>‘)
/usr/lib/python3/dist-packages/future/backports/http/client.py:1: SyntaxWarning: invalid escape sequence ‘_’
“”“HTTP/1.1 client library
/usr/lib/python3/dist-packages/future/backports/http/cookiejar.py:212: SyntaxWarning: invalid escape sequence ‘\d’
“(\d\d\d\d) (\d\d):(\d\d):(\d\d) GMT$”, re.ASCII)
/usr/lib/python3/dist-packages/future/backports/http/cookiejar.py:293: SyntaxWarning: invalid escape sequence ‘\d’
/usr/lib/python3/dist-packages/future/backports/http/cookiejar.py:429: SyntaxWarning: invalid escape sequence ‘\s’
non_junk, nr_junk_chars = re.subn("[1]", “”, text)
/usr/lib/python3/dist-packages/future/backports/test/support.py:1977: SyntaxWarning: invalid escape sequence ‘\d’
m = re.match(“2.6.(\d{1,2})”, kernel_version)
/usr/lib/python3/dist-packages/future/backports/urllib/parse.py:957: SyntaxWarning: invalid escape sequence ‘?’
_queryprog = re.compile('^(.)?([^?]*)$’)
/usr/lib/python3/dist-packages/past/types/oldstr.py:23: SyntaxWarning: invalid escape sequence ‘\d’
=\s; ↩︎
I believe you can forget about this package added when comparing your list to my installation. This package is aimed to ensure compatibility between python2 and python3.
ParaView compilation still not working:
SAT/sat -o “APPLICATION.properties.git_server=‘github’” compile SALOME-9.14.0-native -p ParaView --clean_all
Executing the compile commands in the build directories of the products of the application SALOME-9.14.0-native
SOURCE directory = /home/serge/salome/SALOME-9.14.0-native-UB24.04/SOURCES
BUILD directory = /home/serge/salome/SALOME-9.14.0-native-UB24.04/BUILD
Compilation of ParaView … KO
Compilation: KO (0/1)
script.log (1.5 MB)
