I am trying to do the meshing with Salome but I get this error:
Can’t load mechers plugin library NETGENEngine.dll
can you share the folder PATH in which you installed SALOME ?
From the screen capture you shared, I can see that you do have Python3.10 in your PATH, which can be problematic. Here, you need to:
1/ install SALOME in a a folder which name is not too long, like e.g. C:\SALOME-9.9.0
2/ in order to avoid conflicts between your Python 3.10 and the one embedded with SALOME, you need to patch the run_salome.bat launcher as follows:
a)- start a cmd and type : echo %PATH% to retrieve the PATH environment variable content.
b)- edit file run_salome.bat, and right before:
START %out_dir_Path%\W64\Python\python3.exe %out_dir_Path%\salome %*
add to PATH the output of a) without any reference to C:\User\User\AppData\Local\Programs\Python:
SET PATH= output of step a) without references to C:\User\User\AppData\Local\Programs\Python.
HTH
Tried in the run_salome file.bat add everything from path, except everything related to python. Also in PATH, the version was changed from 310 to just Python. Attached photo
there is a space between SET PATH= and % which needs to be removed.
you can also remove the path which is in cyrilic in case.
then simply double click on run_salome.bat and let us know if it helps. hth
It didn’t help. Removed the space bar and tried to run as administrator… does not work ![]()
hard to guess. so:
C:\SALOME-9.9.0 ?NETGENEngine.dll present in directory: SALOME-9.9.0\W64\NETGENPLUGIN\lib\salome ?run_salome_shell.bat, this will launch a terminal with SALOME environment setecho %PATH% > myenviron.txtenv >> myenviron.txtEnsure that in that file, you don’t have sensitive information which SHOULD not be shared on this forum, and if this is the case, remove it, and upload the file, such that we can have a look.
Regards
Thanks! I’ll answer you tomorrow.
Good afternoon!
myenviron.txt (4.4 КБ)
Can you edit run_salome.bat and right before:
add:
SET PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
and restart SALOME
It doesn’t help… Here’s what error comes out in the console
This PC is located in the domain and the program is installed on behalf of the local administrator
well, then I don’t know.
I just installed SALOME 9.9 as administrator and ran as a normal user and it is fine.
Here is what you can do to check that you do not have some missing library:
DependenciesGuiIf someone else has some ideas, he/she might give some tips.
Hi! Thanks for the help, but unfortunately, nothing helped. I think the problem is in the Python version. So everything worked on the last version. I attach a photo from the Dependencies-walker program
if you compare the screen capture you shared with mine, you can see that either the libraries are not found, or you simply did not run DependenciesGui as described.
DependenciesGuiGood afternoon! Thank you for explaining in more detail. I have everything according to your screenshot ![]()
Thanks for the feedback.
Given that you can install SALOME without being administrator, you can simply install locally SALOME 9.9 and check if if you experience the same issue.
Hello @NabilG I am facing the same issue:
in salome 9.10 installed in w10. I have run the installer as administrator.
EDIT: found the error, I installed the newer version of visual studio Latest supported Visual C++ Redistributable downloads | Microsoft Learn
