After creating some functions to automate tasks like inserting nuts’ footprints and bolts, I would like to contribute an add-on, like the one which makes a pre-partitioned tee.
But how is the process to add something like this? Is there any starting point or example available?
Hi Helio,
sadly I have no answer for your question, but I am very interested in how you managed to automate tasks like inserting nuts etc.
Would you mind to elaborate a little bit? I tried to implemet a slot feature via custom addons and failed miserably.
Thanks in advance!
Wolfgang
Create groups based on properties of the entities (circles in this case),
Insert a concentric circle representing the nut’s footprint, then I proceed to a Partition by hand,
Create the bolts from paired nuts, or isolated nuts.
It’s all very crude yet. I have been using it as a library in the Python command prompt, but I really wish this could be put in a better interface. Would you like to receive a copy?
How did you tried the slot feature? Could you describe how you tried to make it available in the UI of the Geometry module, please?
Salutes.py (9,8,KB)
Here goes it! It’s a work in progress. Let me know of your suggestions and comments.
Could any Salome developer point to some tutorial on how to make things like this available through the UI? I would love to be able to select the target objects just like any other present menu option.
Thank you very much for this interesting information. This is a completely different approach than I had in mind.
I want to create a custom feature using the shaper api as input and output. We will see where this journey goes
