SOLVERLAB GUI not available
I would like to be able to launch SOLVERLAB in GUI mode directly from SALOME gui interface. But I can’t find a way, icon is not present.
System is fresh install of Ubuntu 24.04, with SALOME version is 9.15.0-native tarball. Salome is launched from the terminal, the gui opened well, no error in the terminal, I even could follow a tuto on building a part with the shaper module and succeed with computing a mesh on it.
I tried to recompile salome from source code (in ARCHIVE folder) with sat instructions, I got success messages, including for the SOLVERLAB line, but I still can’t find the module on salomé window.
I tried to follow instructions from GitHub - ndjinga/SOLVERLAB: PDE solver lab using SALOME/MEDCoupling meshes and PETSc matrices but it seems that variable $SOLVERLABGUI doesn’t exist (it’s empty). Sourcing the env_launch.sh on root directory doesn’t help.
What am I missing ?
SOLVERLABGUI interface is deprecated and is not maintained anymore. You should instead use the PYTHON API. See examples here:
Thank you for quick answer, I will try this approach
