SALOMEDS_Tool.hxx has:
typedef std::vector<std::string> ListOfFiles;
and in SALOMEDS_Tool.cxx: PutStreamToFiles:
ListOfFiles aFiles;
char *aFileName = new char[aFileNameSize];
aFiles.push_back(CORBA::string_dup(aFileName));
delete[] aFileName;
The CORBA::string_dup, without a matching CORBA::string_free, obviously leaks memory.
This can be trivially fixed by just removing the CORBA::string_dup.
Bonus points for replacing aFileName with a std::string and using std::move.
How can/should patches be submitted?
sme
February 14, 2022, 2:57pm
3
Hello
There is no leak here as CORBA manages it-self memory chunks that are returned from a function. Try using valgrind to see that everything is OK here
Best regards
CORBA::string_dup returns a plain char*, not a managed object (String_var).
omniORB source code (/omniORB4/stringtypes.h):
class _CORBA_String_helper {
static inline char* dup(const char* s) {
int l = (int)strlen(s);
char* r = alloc(l);
if (r) {
strcpy(r, s);
return r;
return 0;
// As CORBA::string_dup().
sme
February 14, 2022, 4:06pm
5
As far as I see you suggest adding CORBA::string_free as follows
CORBA::string_free( aFiles.back())
But what aFiles will return then, as we destroy its content?
No. Just remove the CORBA::string_dup call.
std::vector<std::string>::push_back(...) calls the std::string constructor and copies the char .
You suggestion is double wrong, it still leaks the temporary char array, but deletes a std::string owned by the vector.
I would submit a patch, but this seems to be impossible here.
sme
February 14, 2022, 5:12pm
7
Indeed, now I see you are right. I’ll push your fix. OK?
Thank you.
Best regards
