I am trying to use shaper for the creation of my geometry and would like to add a fillet to the resulting edges between several intersecting spheres that are fused together.
my issue is that I don’t understand how the selection function works.
when I do it for two spheres in GUI and dump it in a python script. for the fillet creation I am getting the following line:
Fillet_1 = model.addFillet(Part_1_doc, [model.selection("EDGE", "Fuse_1_1/Generated_Edge&Sphere_2_1/Face_1&Sphere_1_1/Face_1&new_weak_name_1")], 2, keepSubResults = True)
what I get from it, is that model.addFillet has 4 arguments, the document, the edges where it should add the fillet, the radius, and if it keeps the sub results. my problem is with the second argument,
is used for the selection of the edges, and I get that model.selection has two arguments, the first one the type, but the second one I do not understand at all how it is created/ how to do it (the logic behind it)
for the selection of a complete feature I use the .result() (for example for the creation of the sphere with its center in Point_1, I use:
Sphere_1 = model.addSphere(Part_1_doc, Point_1.result(), 10)
but originally from the dump study I get:
Sphere_1 = model.addSphere(Part_1_doc, model.selection("VERTEX", "all-in-Point_1"), 10)
as in the previous case, I don’t understand the “all-in-Point_1” (I know it is shown as the text entry in the GUI if the Sphere_1 was created using GUI)
any help would be appreciated as I am completely blocked as there is no info about this in the TUI example.
best regards.
