Given in the x-y plane is a bspline. It should become a path for pipe.
To be able to draw the cross section I need a “plane”. Known is
the endpoint “P” a tangent in “P” and a perpendicular to the tangent of the bspline.
To be able to draw a “plane” some z-coordinate over “P” is needed.
I tried it with the function (see also file) “normal from face”. It does not work
because this normal has no selectable endpoint.
Is there a solution?
With kind regards
plane_search.hdf (34,6 KB)
