Greetings,
As i was trying to install Salome 9.9.0 in Ubuntu 22.04 i had to check for my prerequisites installed in my machine. I followed the README command:
${ROOT}/sat config SALOME-9.9.0-native --check_system
After running this command from the specified directory where Salome files are untared, instead of checking the system i got an ootput:
bash: ./sat: Is a directory
It looks like the “sat” script file is missing from the folder that i untared. If that’s the case can i download the same separately? If yes from where?
Thank you,
Sal
