HI, I need some help , this is my first post, my first time in salome, my first time in everthin:
I installed
- salome meca: Version: salome_meca-lgpl-2024.1.0-1-20240327 Scibian11 Singularity container 2025, January 9th 5.3 Go LGPL a4df42c124f57fdb404e40c686d00fa4a1569365
- On my ubuntu versions 24.04.2 lts codename noble.
- In my thinkpad p15 gen3
4.I have the file in (my documents folder) as soon I run de programs i get this message:
gas@gastp:~$ singularity run salome.sif
- running salome_meca in software rendering mode
++ using container salome.sif
++ using software rendering mode (should usemesa_salomestarter)
(SALOME_Session_Server_No_Server:7476): dbind-WARNING **: 23:15:35.449: Couldnāt connect to accessibility bus: Failed to connect to socket /run/user/1000/at-spi/bus_0: Aucun fichier ou dossier de ce type
Error creating proxy: Impossible de se connecter : Aucun fichier ou dossier de ce type (g-io-error-quark, 1)
ā¦
(SALOME_Session_Server_No_Server:7476): dconf-CRITICAL **: 23:18:36.923: unable to create directory ā/run/user/1000/dconfā: SystĆØme de fichiers accessible en lecture seulement. dconf will not work properly.
ā¦
As soon I enter to asterstudy i recive a small salome windows which says ASTER STUDY: no available versions foun on ālocalhostā. Previos server is selected: ".
meanwhile I observed the terminal this message: SalomeApp_Engine_i::Load() isMultiFile = 0
AsterStudy: dim.-01-23:22:04.817 Opening AsterStudy JSON fileā¦
AsterStudy: dim.-01-23:22:04.818 Use version āstableā (16.7.0)
AsterStudy: dim.-01-23:22:04.818 loading case āCurrentCaseā (1/1)ā¦
AsterStudy: dim.-01-23:22:04.818 loading stagesā¦
AsterStudy: dim.-01-23:22:04.844 case āCurrentCaseā loaded
AsterStudy: dim.-01-23:22:04.984 JSON file reloaded
/opt/salome_meca/V2024.1.0_scibian_univ/prerequisites/Cea_zcracks-32101/plugin/Zcracks/zcracks_plugin.py:26: SyntaxWarning: āis notā with a literal. Did you mean ā!=ā?
if command is not āā:
AsterStudy: dim.-01-23:22:14.975 AsterStudy is activatingā¦
AsterStudy: dim.-01-23:22:14.976 Creating workspaceā¦
AsterStudy: dim.-01-23:22:14.000 Refreshing configuration on localhostā¦
AsterStudy: dim.-01-23:24:41.913 saving case 1-CurrentCaseā¦
AsterStudy: dim.-01-23:27:41.850 saving case 1-CurrentCaseā¦
AsterStudy: dim.-01-23:29:02.594 workspace is ready.
AsterStudy: dim.-01-23:29:02.617 Mounting filesystems for cronosā¦
AsterStudy: dim.-01-23:29:02.675 Mounting sftp://gas@cronos.hpc.edf.fr/scratch/gas/ filesystem: failed
AsterStudy: dim.-01-23:29:02.675 g-io-error-quark: le volume nāimplĆ©mente pas le montage (15)
ā¦
AsterStudy: dim.-01-23:29:03.011 AsterStudy activated -
I am trying to make my first simulation from this video: https://www.youtube.com/watch?v=lFUF5EelFUo
In the minute 15:43 it says I have to save the ouputfile name (cantiliver.rmed) but as soon i try to press the 3 dots all salome meca close itself
I observed that in this moment when salomed crased and closed this messege adde to the other i mentioned befoere appears;
(SALOME_Session_Server_No_Server:7476): dconf-CRITICAL **: 23:50:58.787: unable to create directory ā/run/user/1000/dconfā: SystĆØme de fichiers accessible en lecture seulement. dconf will not work properly.
ā¦
- Please what can i do?
