I have tried opening some old unv file which I converted to med.
In Salome when I use NODE CONTROL> Duble nodes, It is shown to be zero.
Yet there are overlapping nodes between ‘targe’ and ‘conta’ groups.
You can check with mesh info. Each overlapping element has different node connectivity. Also these groups are used with code_aster run in DEF_CONTACT(which will give error if both master and slave faces have same node support). The run works.
Please let me why is this discrepancy.
Regards
Anirudh
mesh2.med (976.7 KB)
