Salome 9.8 - Volume element edges not shown
I just installed 9.8 -thank you for this update!
I notice that salome does not show volume element edges correct. At least my installation does not. See also older post: Volume element edges not shown — SALOME Platform (salome-platform.org)
-Will this issue be fixed in 9.9?
-Another question, how do I uninstall older versions? is it just to remove the installation folder ? rm SALOME-9.7.0-UB18.04-SRC ?
-Thank you for the good work with the program!
BR/Micke
hi, regarding the second questino about uninstalling versions, on Linux, you need to simply delete the installation folder. In addition, you can do the following:
  • remove files $HOME/.config/salome/*9.7.0*
  • close all SALOME instances and remove:
    • /tmp/.*_PortManager.cfg
    • /tmp/.omniORB_*
    • /tmp/.salome/.PortManager.lock
