SALOME 9.13.0 release
CEA, EDF and OPEN CASCADE are pleased to announce SALOME version 9.13.0. It is a public release that contains the results of planned major and minor improvements and bug fixes against SALOME version 9.12.0 released in Januar 2023.
Read SALOME 9.13.0 Release Notes for more details about this release.
Pre-compiled binaries of SALOME 9.13.0 for supported platforms, as well as universal Linux binary packages, can be retrieved from the download page of the site.
The SALOME team
Hi! Curious to know if when using meshio it is also possible to export the tags (groups) alongside the mesh?
Thank you! Is it possible to use the Boundary layer generation algorithm that is native of NETGEN in this release?
we have not tested all meshio formats. Please test for the format you want and report to us or to meshio.
we have not tried Netgen’s built-in boundary layer algortihm yet. It is still the one from SALOME.
Hi! Thanks to all involved in this new release of the Salome platform!
I have tried to download the precompiled Windows 10 versions (both .exe and .zip), but have not been successful.
It appears to me that the download files to which links point to are inexistent on the file server?
Thanks for any help or suggestion on how to proceed!
Thiago.
indeed, there is something bad on the server side, we are investigating the problem.
Concerning mesh formats, I am not sure what the holdup would be in salome since netcdf and moab format specifications are open source. Would it be as simple as writing a plugin with the relevant data structures since the data exists already? Even exodus has an api though on the other hand med has an api for loading data and perhaps the codes you are interested in could be extended with this.
download issues have been solved. You should be able to download SALOME now.
Thank you for the feedback and attention to the issue!
Thiago
I can’t down load SALOME - 9.13.0 - Windows 10 (.exe), there is an error of ā€œThe reCAPTCHA test was failed.ā€. this is why it can’t be download. Thanks
it works for me. Please retry. Make sure that the 2nd checkbox is ticked I have read and accept the terms of use.
If it still fails, please provide information about your OS and web browser.
Thank you for the release
I am using xubuntu 24 (which is a version of ubuntu with xfce desktop environment).
I have downloaded the Salome meca 9.13.0 version file for ubuntu 24 from the official website.
Can you please link me a beginner level tutorial to install it on ubuntu?.
I read the install instructions. It says to use ā€˜sat’ command which is not installed on my system & which I cannot find in apt or apt-get.
Thanks
Are you running SALOME or SALOME Meca ?
In case it’s SALOME, you need to follow the README file instructions.
In case it is SALOME Meca, since it is distributed as a singularity image file (sif), you need to install singularity or apptainer to run it.
Note that questions about SALOME Meca should be addressed on the dedicated forum at this link.
