Dear All,
I am trying to launch Salome 9.11 on Ubuntu 22.04 and it does not work. I have downloaded SALOME-9.11.0-native-UB22.04-SRC ec62885173c137ca0fcb09c4597e23a8.tar.gz, unzipped the archive and when I go in the folder and launch ./salome, i have the following message which appears :
File “/home/pierre/Documents/SALOME-9.11.0-native-UB22.04-SRC/BINARIES-UB22.04/SALOME/bin/salome/salomeContext.py”, line 294, in _startSalome
File “/home/pierre/Documents/SALOME-9.11.0-native-UB22.04-SRC/BINARIES-UB22.04/SALOME/bin/salome/salomeContext.py”, line 381, in _sessionless
import setenv
File “/home/pierre/Documents/SALOME-9.11.0-native-UB22.04-SRC/BINARIES-UB22.04/KERNEL/bin/salome/setenv.py”, line 26, in
from launchConfigureParser import verbose
File “/home/pierre/Documents/SALOME-9.11.0-native-UB22.04-SRC/BINARIES-UB22.04/KERNEL/bin/salome/launchConfigureParser.py”, line 31, in
from salome_utils import verbose, getPortNumber, getHomeDir
File “/home/pierre/Documents/SALOME-9.11.0-native-UB22.04-SRC/BINARIES-UB22.04/KERNEL/bin/salome/salome_utils.py”, line 39, in
import psutil
ModuleNotFoundError: No module named ‘psutil’
I thought about an issue with the dependency, so i ran the following command in the sat folder :
./sat config SALOME-9.11.0-native --check_system
and i obtain :
/usr/bin/env: «python»: Aucun fichier ou dossier de ce type (in French)
Hello NabilG,
Thank you for your answer ! I have installed python-is-python3 which allowed me to launch ./sat config SALOME-9.11.0-native --check_system. Thus it was possible to have the list of the package to install to launch salome (the list was a bit long :). Once the packages necessary are installed… it works !
Thank you very much so, problem fixed.
I got the same problem at running ./salome in the terminal, I try to install python-is-python3. but Can you explain the command to execute?
I executed sudo apt-get install python-is-python3, and try to launch ./salome, and still not working, I check the python version about it, and Python is 3.10.13 and for Python3 is 3.10.13, do I need to Install more extentions to run ./salome?
To check everything, I read at READ ME file, to launch:
./sat/sat config SALOME-9.11.0-native --check_system
At terminal answer was:
Error :
linux_distribution was removed from platform module in Python 3.8+
For python 3.8+ sat requires distro module to get information on linux distribution.
Deat afsilveravi,
I am sorry I did not faced to this issue… However, it appears that install python-is-python3 was not enough for me to be able to launch SALOME. But after installed all the packages necessary it worked. For my side, the command
gave me the list of packages to install and after that it worked…
What do you have when you try to run ./salome ?
Dear Max,
Thank you for your message !
Which error do you have when you run
from the relevant folder ?
This is my console output from bash in Kubuntu 22.04:
happy@happyhippo:~/SALOME/SALOME-9.11.0$ ./sat config SALOME-9.11.0 --check_system
bash: ./sat: Is a directory
(As a sidenote, when I try to run salome from bash with ./salome,
then it appears to start, a splashcrenn shows briefly, and it hoes away and thats all.)
Dear Lumasci,
Your error message is very weird… Have you tried to reinstall python and python-is-python3 ?
Have you tried to run another python code with:
python3 my_python_code.py
you need to install the system package which ships this library, namely libqwt-qt5-6. More generally, to find which package ships a .so which is reported as not found, install apt-file tool and run: apt-file find /usr/lib/libqwt-qt5.so.6
The problem is that the path is incorrect. To make matters worse, the correct path, /usr/lib/x86_64-linux-gnu/libopenblas.so.0, is a symlink to /etc/alternatives/libopenblas.so.0-x86_64-linux-gnu, which confuses apt-file. Basile’s suggested approach is better.
Many of the libraries were missing → solved installing each of them individually with a sudo apt install missinglib. Note for newbies like me the ./sat config SALOME-9.14.0-native --check_system command should be run in the sat folder of Salome
Installing the libopenblas-dev helped to resolve the last problem
Thnaks for the didactive answer for non specialists
