Hi there,
So I have been reading the SALOME KERNEL pages for running the salome scripts straight from terminal or powershell. Basically I have a working python script for use in salome. However instead of manually opening the Salome gui, selecting ‘load script’ and then repeating, I would like to do it from terminal.
However all the notes in SALOME KERNEL start with:
‘salome start [options] …’
or
‘salome shell [options] …’
https://docs.salome-platform.org/latest/tui/KERNEL/running_salome_page.html
Here is a link to the said salome kernel page I have mentioned.
I however do know where this directory is in the power shell? I have set my directory to C:\SALOME-9.12.0 and in there is run_salome.bat and a few others but I am completely lost as to how to locate myself so I can start using the commands from the SOLOME KERNEL reference page.
This is my first time trying to use terminal / powershell as I try to integrate using Salome with two other software directly from terminal.
Happy to explain further or clear any of that up.
Thanks
