I would like to rotate and eventually translate a mesh.
With SMESH module, it seems pretty simple to achieve this
But I cannot figure out if it’s possible to keep the definitions of Mesh Groups from the original mesh.
Any suggestion?
Best
Any suggestion?
Best
Yes it is possible to keep the groups.
See the documentation here
In your case you should use the “Create a new mesh” option and also check “copy groups”.
@fred Is there a way to check that there are no elements with negative jacobian in the created mesh? This may happen with mesh having very small elements in my experience.
You can use filter + group and check the number of elements
