I found that structured & unstructured hybrid mesh generation not so reliable with Salome. I wanted to check with the community that if the method I use is wrong. All files and images are attached below.
Explanation:
dividedBox case:
In shaper I added a box and split it with a plane.
- Created groups for sub-volumes and some surfaces.
- Created mesh using 3D tetrahedralization method and maximum size.
- Created sub-mesh on one volume group, set 3D Mapped Hexahedralization and on 1D edgeSize.
The mesh is generated as expected. Sub-mesh is entirely consist of structured hexahedral cells, where the other volume-group meshed with unstructured tetrahedral cells and pyramids where the two volumes meet.
Now my problem starts here.
innerOuter case:
- I created another box. This time I cut it with 5 planes. Think of it like a thick walled box without a lid and the air inside.
- I created inner and outer volume groups.
- Followed same meshing procedure. 3D tetrahedral mesh with structured sub-meshed volume group.
The mesh was not as expected. I was expecting strict structured hexahedral mesh on the sub-meshed volume. But instead seemingly random hexahedral regions and mostly tetrahedral mesh.
I uploaded the both images below.
So my question: Is there a reliable way to get expected hybrid mesh on every time and on every valid geometry?
Below figures show the first “dividedBox” case.
Below figures show the geometry and mesh of unexpected result from “innerOuter” case.
Here are both case files:
dividedBox_unmeshed.hdf (262.0 KB)
innerOuter_unmeshed.hdf (216.1 KB)
