Hello All
Hope all is well in your part of the world.
Salome came recommented from ElmerFEM. My aim with Salome is to create groups.
How can I select just the triangular faces that I have within the selection box?
- Would I use Range of IDs? But what are the IDs within the selection?
Or any other filter?
Thank you & Regards,
love the work you all are doing here,
All the best!
fred
2
You can use a filter call “Belong to Geom”:
- Go to GEOM to create a box that will contain the part you want to select
- Go back to SMESH:
- Create Group, select your mesh
- Select the elements type = Face
- Group Type = Group on filter
- click the “Set Filter” button and select the box created in GEOM
This is very helpful Fred.
Manual selection worked without use of filters, which was great.
Thanks
