Problem with getting salome source code
I’m trying to get the source code from salome by following the FAQ.
But when I type the command in the terminal I get:
C:\SALOME-9.8.0\SOURCES>./sat prepare Salome-9.8.0
‘.’ is not recognized as an internal command
or external, an executable program or batch file.
version windows 10
for windows, in principle source code is not embedded in distributed archives. Are you trying to compile some SALOME module ?
If so, you will need some guidance on how to proceed.
