Parts (Not Loaded) when opening Shaper file
I am still very new so still learning. I have tried hard to search for a solution to this problem.
When I open my file in Shaper, only one part (the last modified) appears in the Part set. All the rest show “Part x (Not Loaded)” and I have to manually activate each one, then go back to the Part set, then activate another etc. Is this intentional? If it is intentional what is the purpose for not loading all the parts when I open the file? If not intentional, is this an easy issue to fix?
Same problem here, on 9.14.
Does someone know a better way to load all the Parts?
yes I think it is intentional to not load all the parts for performance reasons.
unfortunately I don’t think there is a workaround.
