I am debugging a TUI script, that in my case is done mostly in the Geometry module.
and a life improvement to the debuging of it, would be to be able to add some lines to the script so when run, the GUI opens de geometry module and furthermore, it updates/refreshes it (as F5 behavior in the GUI)
is there any way to achieve this? i could not find it in the documentation.
best regards,
What do you mean by refresh? Display the GEOM object or simply update the SALOME Object browser?
In order to activate a module (switch to it) via Python, I used the following lines:
import SalomePyQt
sgPyQt = SalomePyQt.SalomePyQt()
sgPyQt.activateModule('Geom') # Or GEOM, forgot what is the correct string
# And for example to refresh the SALOME Object browser
import salome
salome.sg.updateObjectBrowser()
Gregor
Hello gregor,
first of all thanks for your help,
secondly, the correct string is âGEOMâ, nevertheless, this gives a view setup that is not correctly, see screenshot, the tools are all misplaced and what is worst (and what I need) is that the object browser is not displayed.
this command throws an error when I add it to the script as following:
File ââ, line 1, in
File âC:/Users/Microreactors/Documents/MEGAsync/These doctoral/OpenFoamSalomeFreeCad_ScriptsCases/structuredMeshingGenerator/structuredMeshingGenerator.pyâ, line 30, in
File âC:\SALOME-9.9.0\W64\GUI\lib\python3.6\site-packages\salome\libSALOME_Swig.pyâ, line 166, in
getattr = lambda self, name: _swig_getattr(self, SALOMEGUI_Swig, name)
File âC:\SALOME-9.9.0\W64\GUI\lib\python3.6\site-packages\salome\libSALOME_Swig.pyâ, line 80, in _swig_getattr
raise AttributeError(ââ%sâ object has no attribute â%sââ % (class_type.name, name))
AttributeError: âSALOMEGUI_Swigâ object has no attribute âupdateObjectBrowserâ
for info, i add it to my script before the geompy = geomBuilder.New()
best regards,
ah sorry, first I noticed that the updateObjectBrowser is the wrong function. The correct one is
salome.sg.updateObjBrowser()
In the meantime I will see how to show the Object Browser. I think there is Qt function exposed to python for most SALOME GUI functionalities.
Gregor
hello gregor,
the function works correctly, thank you a lot.
another questions if I may regarding the interaction between TUI and the GUI and whats is displayed,
regarding the SMESH module, how can we display a mesh and change its color in the view?
i got it done for the geometry module by using:
gg = salome.ImportComponentGUI("GEOM")
for solid in solids:
listDisplaySolids.append(geompy.addToStudy(solid,'solid '+str(countSolids)))
for i in listDisplaySolids:
gg.createAndDisplayGO(i)
gg.setDisplayMode(i,2)
gg.setColor(i,random.randint(0,255),random.randint(0,255),random.randint(0,255))
gg.setVerticesMode(i, False)
gg.setTransparency(i,0)
is it possible to do the same for the SMESH module?
display in the VTK scene the different meshes, change the color of each of them to differentiate and lastly use the âfit allâ to show the view of them (this I did not found it either for the Geometry module, OCC scene)?
furthermore, the code that I cited in this post âworks well and intendedâ, only after running the script if i copy paste it in the python console, but if I add it to the script that I am running from file/load script, for example, the solids will all be shown in the same color intead of having random colors for each of them.
you can call display from smeshâs gui:
smesh_gui = salome.ImportComponentGUI('SMESH')
mesh_id = salome.ObjectToID(Mesh_1.mesh)
smesh_gui.display(mesh_id)
See available functions in SALOME Mesh Module Developer: SMESH_Swig Class Reference
And an example to manage the colors in this script:
create_and_display_box_v9.py (2,7 Ko)
Hello Christophe,
thanks for the insight. I almost got everything I was looking for studying your script and looking in the documentation, nevertheless, i could not find one thing, how to display the display mode to âshrinkâ.
I found that smesh_gui.properties we have the .shrinkFactor which will modify the this shrinkish that I am looking for, furthermore I found also smesh_gui.setDisplayMode(group_id,1) which will change the display mode between nodes (0), wireFrame (1), shading (2). but i could not find how to change it to display mode/ shrink (then the .shrinkFactor will have an impact over the displayed view.)
how can I change to this display mode?
regards,
