I make a fresh install of Salome for Windows 11 (HP laptop, Intel Iris Xe Graphics card), create some geometry, go to MESH, then choose Create Mesh / NetGen 1D-2D-3D, 3D parameters icon. Now, the panel with selection of mesh density etc. does not open. Instead, Salome crashes with a message:
TkopenGL.
OpenGL context reports version 4.6 but does not export required functions for 4.5 (glGetnTexImage).
Please report this issue to OpenGL vendor „intel”.
I encountered a very similar problem before. At first, it was a Windows 10 system with Salome 9.9 through 9.11 (I tested different releases). The program crashed at the same moment as described above (yet it did not produce any error message, just closed). Interestingly, it STARTED working the next day, even if I did not change anything - perhaps it was due to some system updates?
Is it a known problem? Is there a fix for that?
Regards and thanks in advance
Marek
