Novato en linux y salome
hello, i am really bad installing software
could you hive me some tutorial… please?
I use the tar-gz file
I extracted the file
and then… this step…
./sat config SALOME-9.14.0-native --check_system
whit this result
WARNING: Some run time system dependencies are missing!
Please install them with dpkg-query before running salome
missing run time dependencies : python3-babel python3-pytest-cython python3-jinja2 python3-sphinx python3-alabaster python3-cftime libcminpack1 python3-docutils fftw libfreeimage3 python3-imagesize liblapacke clang libmetis5 python3-netcdf4 libnlopt0 libnlopt-cxx0 python3-nlopt python3-nose python3-numpydoc python3-pandas python3-patsy libqwt-qt5-6 libfftw3-double3 libopenexr25 libilmbase25 libffi7 libxml++2.6-2v5 python3-stemmer python3-sphinx-rtd-theme python3-sphinxcontrib.websupport sphinx-intl python3-statsmodels python3-toml
WARNING: Some compile time system dependencies are missing!
Please install them with dpkg-query before compiling salome
missing compile time dependencies : libcminpack-dev libcppunit-dev fftw-dev libfreeimage-dev libgraphviz-dev liblapacke-dev llvm-dev libmetis-dev libnlopt-dev libnlopt-cxx-dev python3-patsy libqwt-qt5-dev libxcb-dri2-0-dev libxkbcommon-dev libxkbcommon-x11-dev libxi-dev libxpm-dev libxcursor-dev libqt5svg5-dev libqt5x11extras5-dev qtxmlpatterns5-dev-tools libxml++2.6-dev libgmp-dev libmpfr-dev python3-sip-dev python3-statsmodels swig
here you need to install the system dependencies which have been found as being missing with apt tool.
If you’re not comfortable with Linux commands, better use the universal binary which will ease things and once the archive extracted, run:
chmod u+x run_salome.sh
./run_salome.sh
HTH
Que hago? what should I do?
1- Launch a terminal (can be done with a shortcut [CTRL+ALT+t] on ubuntu)
2- in that terminal, type:
cd  SALOME-9.14.0 # assuming SALOME-9.14.0 is in that directory
./run_salome.sh
Muchas gracias! Thanks a lot ! it works!
puedo preguntar como instalar ahora Salome MECA y Salome CFD?
Here you need to address your question to the corresponding forums:
LINUX PROBLEM.pdf (535.1 KB)
HI, I am not sure , I ca not use salome at all, if i try to use aster code, it crasehd, if i can post this here this is my second time , I look for a solution, I have attached a file with the complite explanation of my issue
