I need to create multi-region case which has 3 cylinder region. Outer and Mid regions are solid, inner region is the fluid region. Inlet for the inner region intersecting with outer and mid region while outlet intersectiong only the outer region (It looks unphysical but this is the geometry I have to create). I defined all faces and volumes but when I split the regions the code recognize inlet as face-zone.
I add the scheme for the problem and hdf file. Any suggestions will be appreciated.
multiRegion.hdf (3.8 MB)
Kind regrads,
Said.
