Missing CPPUNIT_ROOT_DIR_EXP
Hello, I’m trying to rebuild HELLO Module from below SALOME Documentation
HELLO sample module reference manual v.9.15.0: Construction, installation
However, I’ve encountered error when I’m running ‘Construction, Installation’ part, specifically during ‘cmake -DCMAKE’.
I’ve go to the folder, and find out that there is no such folder.
Need some advice, thanks!
you need to setup the developer mode. To do that, simply run ./install_bin.sh which will:
  • copy BINARIES-CO8 to INSTALL
  • fix all paths occurences to current installation directory
once this done, you can regenerate:
  • SALOME launcher: ./sat/sat launcher SALOME-9.10.0 (--use_mesa)
  • environment scripts: ./sat/sat environ SALOME-9.10.0
Sorry for the late reply. I’d like to ask some questions first:
  1. Do I need to copy files from original SALOME-9.10.0? If so, what files should I copy into my HELLO1_SRC directory? (Cause my HELLO!_SRC directory is based on the module tree structure). Or do I need to put my HELLO1_SRC inside the SALOME-9.10.0/BINARIES-CO8 folders?
  2. What and where is the env_products.sh (the one in the ‘Construction, Installation’ step) located? Cause my original SALOME-9.10.0 folder only include env_source.sh and install_bin.sh.
  3. I have follow your command (putting HELLO1_SRC module in SALOME-9.10.0) but still getting the same error.
I’m sorry for asking too much, but I really appreciated your response. Thanks
