I have installed Salome-9.13 Linux Universal version as I am installing it with Ubuntu-24 which is not supported as of now.
Before the start I have sourced the env_launch.sh and then tried to run salome
source env_launch.sh
salome
While starting I am getting the output
File “/usr/lib/command-not-found”, line 23, in
import gettext
File “/home/shobhit-linux/Pre-post/SALOME-9.13.0/BINARIES-CO7/Python/lib/python3.9/gettext.py”, line 50, in
import re
File “/home/shobhit-linux/Pre-post/SALOME-9.13.0/BINARIES-CO7/Python/lib/python3.9/re.py”, line 125, in
import sre_compile
File “/home/shobhit-linux/Pre-post/SALOME-9.13.0/BINARIES-CO7/Python/lib/python3.9/sre_compile.py”, line 17, in
assert _sre.MAGIC == MAGIC, “SRE module mismatch”
AssertionError: SRE module mismatch
I understand that it could be a problem related to Python version. The python version I am having on my system is Python 3.9.14 which I checked using
python --version
Thanks in advance.
NabilG
September 4, 2024, 11:22am
2
can you try in a new terminal:
SALOME-9.13.0/run_salome.sh
and if it still fails, share output of env command line (make sure not to share some sensitive data).
Actually while trying to fix the issue. I replaced SALOME9.13 with SALOME9.12 but the issue still persists. I can not find the run_salome.sh. The folder consists following files.
The env output is too large.
SPHINXDIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
SHELL=/bin/bash
TBBROOT=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/tbb
SESSION_MANAGER=local/shobhit-linux-Inspiron-5502:@/tmp/.ICE-unix/2318,unix/shobhit-linux-Inspiron-5502:/tmp/.ICE-unix/2318
OMNIORBPY_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/omniORB
WM_COMPILER=Gcc
SWIG_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/swig
QT_ACCESSIBILITY=1
SALOME_ON_DEMAND=HIDE
PYCALCULATOR_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/PYCALCULATOR
GMSHPLUGIN_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/GMSHPLUGIN
COLORTERM=truecolor
PMML_INCLUDE_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/pmml/include
MPI_C_COMPILER=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/openmpi/bin/mpicc
CSF_MDTVTexturesDirectory=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/CAS/share/opencascade/resources/Textures
CONFIGURATION_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/SOURCES/CONFIGURATION
SPHINX_EXECUTABLE=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python/Scripts/sphinx-build.exe
XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg
OT_VERSION=1.21
PARAVIEW_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/ParaView
MMGT_REENTRANT=1
PYTHONBIN=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python/bin/python3
USERLOGIN=shobhit-linux
OTGUI_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/PERSALYS
SPHINXCONTRIB_WEBSUPPORT_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
XDG_MENU_PREFIX=gnome-
GDAL_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/gdal
NETGENPLUGIN_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/NETGENPLUGIN
CSF_UnitsLexicon=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/CAS/share/opencascade/resources/UnitsAPI/Lexi_Expr.dat
WORKDIR4LOG=tmp/s-sac-dm2s-salome
GNOME_DESKTOP_SESSION_ID=this-is-deprecated
TKLIBPATH=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/tcl/lib /home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/tcl/lib/tk8.6
TOPIIVOLMESH_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/TopIIVolMesh
ROOTSYSLIB=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/root/lib:
PYGMENTS_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
NETGEN_BIN=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/netgen/bin
PETSCDIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/petsc
NUMPYDOC_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
SPHINX_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
OPENTURNS_HOME=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/openturns
COMPONENT_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/COMPONENT
SIP_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/sip
PKG_CONFIG_PATH=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/freetype/lib/pkgconfig:
CoreFlows=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/SOLVERLAB/bin/CoreFlowsMainExe
CGAL_ARCH_PATH=/usr/lib/openfoam/openfoam2312/ThirdParty/platforms/linux64Gcc/cgal-system
TK_LIBRARY=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/tcl/lib/tk8.6
Eigen3_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/eigen
GEOM_PluginsList=BREPPlugin:STEPPlugin:IGESPlugin:STLPlugin:XAOPlugin:VTKPlugin:AdvancedGEOM
PYQT_SIPS=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/PyQt/sip
PYTHON_VERSION=3.6
ZEROMQ_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/zeromq
CSF_ShHealingDefaults=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/GEOM/share/salome/resources/geom
SPHINX_INSTALL_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
FOAM_MPI=sys-openmpi
SCIPY_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
HDF5_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/hdf5
PACKAGESPY_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/packagespy
GNOME_SHELL_SESSION_MODE=ubuntu
HDF5_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/hdf5
SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
CGNS_LIBRARY=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/cgns/lib/libcgns.so
PYQT_SIPS_DIR=
HDF5_INCLUDE_DIRS=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/hdf5/include
MESHGEMS_VERSION_PATCH=1
KERNEL_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/KERNEL
CGNS_INCLUDE_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/cgns/include
NETGENHOME=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/netgen
PLANEGCS_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/planegcs
BABEL_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
GDALHOME=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/gdal
LAPACK_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/lapack
WM_PRECISION_OPTION=DP
SPHINX_RTD_THEME_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
WM_PROJECT_USER_DIR=/home/shobhit-linux/OpenFOAM/shobhit-linux-v2312
PACKAGING_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
MEMORY_PRESSURE_WRITE=c29tZSAyMDAwMDAgMjAwMDAwMAA=
CoreFlows_PYTHON=ON
PTSCOTCH_INCLUDE_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/scotch/include
METIS_INCLUDE_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/metis/include
WM_MPLIB=SYSTEMOPENMPI
PTSCOTCHDIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/scotch
FREETYPE_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/freetype
MESHGEMSHOME=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/MeshGems
FMILIBRARY_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/FMILibrary
GEOM_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/GEOM
HOMARD_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/HOMARD
XMODIFIERS=@im=ibus
FREETYPE_INCLUDE_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/freetype/include
DESKTOP_SESSION=ubuntu
FREETYPE_LIBRARY=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/freetype/lib
SHAPER_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/SHAPER
PRODUCT_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0
REQUESTS_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
PYTHON_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
LIBXML_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/libxml2
URANIE_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/URANIE
MPI_Fortran_COMPILER=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/openmpi/bin/mpifort
SAMPLES_SRC_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/SOURCES/SAMPLES
PARALLEL_VISU=1
MED2HOME=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/medfile
FOAM_RUN=/home/shobhit-linux/OpenFOAM/shobhit-linux-v2312/run
FREEIMAGE_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/freeimage
ROOT_SALOME_INSTALL=/home/shobhit-linux/Pre-post/SALOME-9.12.0
ROOT_INCLUDE_PATH=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/URANIE/include:
CERTIFI_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
C3PODIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/C3PO
CMINPACK_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/cminpack
GTK_MODULES=gail:atk-bridge
IMAGESIZE_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
SIX_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
FMIL_HOME=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/FMILibrary
GDAL_VERSION=2.4.0
PWD=/home/shobhit-linux/Pre-post/SALOME-9.12.0
PILLOW_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
LOGNAME=shobhit-linux
XDG_SESSION_DESKTOP=ubuntu
SALOME_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/SALOME
TCL_SHORT_VERSION=8.6
HELLO_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/HELLO
TBB_ROOT=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/tbb
ZEROMQHOME=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/zeromq
XDG_SESSION_TYPE=x11
PSUTIL_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
VTK_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/ParaView
WM_OPTIONS=linux64GccDPInt32Opt
OPENCV_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/opencv
OTGUI_HTML_DOCUMENTATION_PATH=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/PERSALYS/share/otgui/doc/html/
MPI_CXX_COMPILER=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/openmpi/bin/mpicxx
WM_ARCH=linux64
GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1
SYSTEMD_EXEC_PID=2362
MESHGEMS_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/MeshGems
SALOME_MG_KEYGEN_LIB_PATH=/home/salome-public/prerequis/LICENCE/libSalomeMeshGemsKeyGenerator-2.15-1-CO7.so
FFTW_ARCH_PATH=/usr/lib/openfoam/openfoam2312/ThirdParty/platforms/linux64Gcc/fftw-system
TCLLIBPATH=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/tcl/lib /home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/tcl/lib/tcl8.6
PYUIC5=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/PyQt/bin/pyuic5
EIGEN_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/eigen
EMBREE_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/embree
MARKUPSAFE_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
XAUTHORITY=/run/user/1000/gdm/Xauthority
TBB_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/tbb
SETUPTOOLS_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
BLSURFPLUGIN_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/BLSURFPLUGIN
HDF5HOME=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/hdf5
BLAS_SRC=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/lapack/BLAS/SRC
NETGEN_LIBRARIES=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/netgen/lib
CURRENT_SOFTWARE_INSTALL_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/ADAO
MPI_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/openmpi
FOAM_TUTORIALS=/usr/lib/openfoam/openfoam2312/tutorials
WM_LABEL_SIZE=32
WM_PROJECT=OpenFOAM
CoreFlows_GUI=ON
MPI4PY_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python/lib/python3.6/site-packages
TCLHOME=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/tcl
SETUPTOOLDIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
SALOME_MODULES_ORDER=SHAPER:SHAPERSTUDY:GEOM:SMESH
YDEFX_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/YDEFX
DOCUTILS_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
WINDOWPATH=2
IDNA_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
FOAM_APPBIN=/usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin
CYCLER_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
WM_THIRD_PARTY_DIR=/usr/lib/openfoam/openfoam2312/ThirdParty
METIS_BIN=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/metis/bin
ospray_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/ospray/lib/cmake/ospray-2.4.0
OTGUI_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/PERSALYS
USERNAME=shobhit-linux
SNOWBALLSTEMMER_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/Python
TBB_LIBRARY_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/tbb/lib
SHLIB_PATH=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/root/lib:
LANG=en_US.UTF-8
PYQTDIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/PyQt
DYLD_LIBRARY_PATH=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/root/lib:
WM_LABEL_OPTION=Int32
TK_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/tcl
SALOMEBOOTSTRAP_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/SALOMEBOOTSTRAP
GHS3DPLUGIN_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/GHS3DPLUGIN
MPIEXEC_EXECUTABLE=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/openmpi/bin/mpiexec
LIBBATCH_ROOT_DIR=/home/shobhit-linux/Pre-post/SALOME-9.12.0/BINARIES-CO7/LIBBATCH
I hope it helps.
I will continue it in multiple replys.
NabilG
September 4, 2024, 2:56pm
6
indeed run_salome.sh is shipped with SALOME-9.13.0
Then, it is quite hard to guess from your message (it would be great if you could format your messages!)
Can you do the following instead of running env_launch.sh
start a new terminal without running env_launch.sh. I assume that there is nothing in your $HOME/.bashrc which changes the PATH, LD_LIBRARY_PATH abd PYTHONPATH environment variables
in that terminal execute:
cd <where you installed SALOME 9.13>
I reinstalled the SALOME9.13.0
Executing
gave the following output
python3: can’t open file ‘/home/shobhit-linux/Pre-post/SALOME-9.13.0/bin/salome/salomeContext.py’: [Errno 2] No such file or directory
NabilG
September 4, 2024, 6:35pm
8
Interesting.Can you then simply:
either edit file run_salome.sh and set to SALOME-9.13.0 location at line 4
SALOME_PLATFORM_ROOT_DIR=<path to SALOME-9.13.0>
and run the script again;
or in a terminal, type:
export SALOME_PLATFORM_ROOT_DIR=<path to SALOME-9.13.0>
export PYTHONHOME=$SALOME_PLATFORM_ROOT_DIR/BINARIES-CO7/Python
export LD_LIBRARY_PATH=$PYTHONHOME/lib
$PYTHONHOME/bin/python3 $SALOME_PLATFORM_ROOT_DIR/salome
In addition, please check whether your installation is not corrupted. This file sits in:
SALOME-9.13.0/BINARIES-CO7/KERNEL/bin/salome/salomeContext.py
Thanks alot!
It worked perfectly with the suggestions provided.
In my case, on Ubuntu 24.04.1 LTS, using the SALOME Universal Linux distribution and executing:
~/SALOME-9.13.0$ ./salome
I got lot of errors. Fortunately, when I execute:
~/SALOME-9.13.0$ ./run_salome.sh
it works well .
