I downloaded SALOME-9.11.0, but when I compile ./salome I get this error message
SALOME_Session_Server_No_Server: error while loading shared libraries: libOT.so.0.21: cannot open shared object file: No such file or directory
Is there any way to resolve it ?
I have installed all the prequisites required for SALOME and still having the same issue.
hi,
can you provide us with some additional informations about your OS (run cat /etc/os-release) as well as which distribution you’re trying to run here?
regards.
starting from your list and comparing to what we have, it seems that you need at least to install the following packages which at first sight seem to be required and are missing from the output of config --check_system command:
