Issue with installing salome on ubuntu 22.04
I’m trying to install salome on VirtualBox Ubuntu 22.04 (Salome version Ubuntu 20)
everything work until the compile phase when some module does’nt compile.
here an exemple :
mahefpc@mahefpc-VirtualBox:~/SALOME-9.8.0-native-UB20.04-SRC$ ./install_bin.sh
Warning: INSTALL already exists! Please rename or delete it before executing this script
mahefpc@mahefpc-VirtualBox:~/SALOME-9.8.0-native-UB20.04-SRC$ ./sat config SALOME-9.8.0-native
mahefpc@mahefpc-VirtualBox:~/SALOME-9.8.0-native-UB20.04-SRC$ ./sat prepare SALOME-9.8.0-native -p omniORB,omniORBpy
Clean the source directories …OK
Getting sources of the application SALOME-9.8.0-native
workdir = /home/mahefpc/SALOME-9.8.0-native-UB20.04-SRC/salomeTools/…
omniORB: arc:/home/mahefpc/SALOME-9.8.0-native-UB20.04-SRC/ARCHIVES/omniORB-4.2.3.tar.gz … OK
omniORBpy: arc:/home/mahefpc/SALOME-9.8.0-native-UB20.04-SRC/ARCHIVES/omniORBpy-4.2.3.tar.gz … OK
Getting sources of the application: OK (2 / 2)
Patching sources of the application SALOME-9.8.0-native
Patching sources of the application: OK (2 / 2)
mahefpc@mahefpc-VirtualBox:~/SALOME-9.8.0-native-UB20.04-SRC$ ./sat compile SALOME-9.8.0-native -p omniORB,omniORBpy
Executing the compile commands in the build directories of the products of the application SALOME-9.8.0-native
SOURCE directory = /home/mahefpc/SALOME-9.8.0-native-UB20.04-SRC/salomeTools/…/SOURCES
BUILD directory = /home/mahefpc/SALOME-9.8.0-native-UB20.04-SRC/salomeTools/…/BUILD
Compilation of omniORB … KO
Compilation of omniORBpy … ERROR : the following mandatory product(s) is(are) not installed: omniORB
Compilation: KO (1/2)
UB22.04 , which was released about a month ago, is not yet supported.
You can either use the universal binary (read carefully the README file about uncommenting some lines in SALOME launcher if needed) or try to compile it by yourself and share your experience.
To understand the issue about omniORB compilation reported by SAT, you can look at file LOGS/omniORB/script.
HTH
Any update on this issue? I also tried installing Salome (9.9.0) on Ubuntu 22.04 and failed the same way. Any suggestion on how can I procede?
I was new to Salome and didn’t notice there was Linux Universal version. I downloaded and run it without any change on both Ubuntu 22.04 and wsl (win11). Both worked. I wanted to give this feed back incase it might be useful to someone else.
Hi! I am trying to run SALOME 9.10 on Ubuntu “Jammy” which refers to the codename for Ubuntu version 22.04 LTS (Long Term Support). I installed Ubuntu as a docker image and installed all the dependencies (both aptget and pip install). When I try to run mesa_salome from a VNC client, I get the the error message “session server is not found”. What could be the issue? All the code is the repo “GitHub - giuseppeabbiati1984/calculix” under the subfolder “v2_21\to_compile”. Also the screenshot of the error screen is included.
PS All dependencies are installed.
can you check against the SingularityCE file attached to this artifact and check what could be missing ?
I will share this monday the output of apt list --installed for Ubuntu 22.04.
In addition, how do you launch your docker ?
SALOME.Ubuntu.22.04.def (5.4 KB)
