Hi !
I have a complex geometry got from a STEP file that I’m trying to mesh using smeshBuilder in Salome. As some solids are very small compared to others, we need to define a characteristic mesh size different :
# Create mesh for every solid
for solid in Solids: # Solids is a list gathering all Solids of the geometry
Name = solid.GetName()
algo3d = EyeMesh.Tetrahedron(algo=smeshBuilder.NETGEN_1D2D3D, geom=solid)
algo3d.SetName(Name)
if "Lamina" in Name:
lamina_params = algo3d.Parameters()
lamina_params.SetMaxSize(hsize_lamina)
lamina_params.SetMinSize(hsize_lamina/5)
else:
eye_params = algo3d.Parameters()
eye_params.SetMaxSize(hsize_eye)
smesh.SetName(algo3d, solid.GetName() )
print("Define NETGEN Hypothesys for %s"%Name)
in the terminal it print this error
BFGS update error2
BFGS update error2
BFGS update error2
th. 140176033838848 - Trace /volatile/salome/jenkins/workspace/Salome_master_native_UB20/SALOME-9.7.0-native-UB20.04/SOURCES/SMESH/src/SMESH/SMESH_subMesh.cxx [2051] : NETGEN_2D3D failed on sub-shape #1527 with error COMPERR_BAD_INPUT_MESH "NgException at Volume meshing: Stop meshing since surface mesh not consistent
Some edges multiple times in surface mesh"
and in the GUI, I have the following error displayer in the window “Mesh computation failed” :
Algorithm Sub-shape Error
Invalid input mesh. NgException at volume meshing :
1 VitreousHumor Retina (0:1:1:7:9) Stop meshing since surface mesh not consistant
Some edges mutiple times in surface mesh
But the code
algo3d = EyeMesh.Tetrahedron(algo=smeshBuilder.NETGEN_1D2D3D)
algo3d.SetName("Eye")
param = algo3d.Parameters()
param.SetMaxSize(hsize_eye)
works well. Actually, it doesn’t give a mesh with tiny elements everywhere, but still, we cannot choose the size for the different parts.
What could I do to set it correctly, without mistake ?
Thanks
