Thank you very much.
It works, thanks
Salome doesn’t work on Wayland, right? I had to revert my system to X11.
I raised the question to one colleague of mine to check whether the Debian 12 we have at hand could be used to check this wayland display server issue you’re raising here.
If I get it, you mean that SALOME does not start if you’re using Wayland, SALOME does not start ?
thanks.
Yes, Salome does not open when using KDE Plasma 6 on Wayland.
Just to confirm the behavior. Salome opens, but when I try any module, Geometry for instance, it crashes. It gives the following message:
X Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 3 (X_GetWindowAttributes)
Resource id in failed request: 0xf
Serial number of failed request: 10
Current serial number in output stream: 11
hello @NabilG
after the new update of tuxedo (tuxedos 4) which was rebased on ubuntu 24.04, salome stoped working again,
if I run
./mesa_salome
File "/home/franco/Programs/Salome/SALOME-9.13.0/./mesa_salome", line 77, in main
from salomeContext import SalomeContext, SalomeContextException
File "/home/franco/Programs/Salome/SALOME-9.13.0/BINARIES-CO7/KERNEL/bin/salome/salomeContext.py", line 26, in <module>
from parseConfigFile import parseConfigFile
File "/home/franco/Programs/Salome/SALOME-9.13.0/BINARIES-CO7/KERNEL/bin/salome/parseConfigFile.py", line 49, in <module>
class MultiOptSafeConfigParser(configparser.SafeConfigParser):
AttributeError: module 'configparser' has no attribute 'SafeConfigParser'. Did you mean: 'RawConfigParser'?
File "/home/franco/Programs/Salome/SALOME-9.13.0/./mesa_salome", line 1351, in <module>
main(args)
File "/home/franco/Programs/Salome/SALOME-9.13.0/./mesa_salome", line 1343, in main
except SalomeContextException as e:
UnboundLocalError: cannot access local variable 'SalomeContextException' where it is not associated with a value
also for info:
from distro import linux_distribution
print(linux_distribution())
('TUXEDO OS', '24.04', 'noble')
cat /etc/os-release
NAME="TUXEDO OS"
VERSION="24.04.1 LTS"
ID=tuxedo
ID_LIKE="ubuntu debian"
PRETTY_NAME="TUXEDO OS"
VERSION_ID="24.04"
HOME_URL="https://tuxedocomputers.com/"
SUPPORT_URL="https://support.tuxedocomputers.com/"
BUG_REPORT_URL="https://gitlab.com/tuxedocomputers/development/tuxedo_os/os"
PRIVACY_POLICY_URL="https://www.tuxedocomputers.com/en/Privacy-policy.tuxedo"
VERSION_CODENAME=noble
UBUNTU_CODENAME=noble
in /home/franco/Programs/Salome/SALOME-9.13.0/sat/src/internal_config/distrib.pyconf
I have "tuxedo os" : "UB"
lastly
sudo apt install python-is-python3
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
python-is-python3 is already the newest version (3.11.4-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
this is with salome 9.13.0 universal distribution
also, if I try salome 9.13 ubuntu 24.04 version I get (with ./salome and ./mesa_salome
SALOME_Session_Server_No_Server: error while loading shared libraries: libgdal.so.34: cannot open shared object file: No such file or directory
then it does nothing, and when I stop the command (ctr+C)
I get:
^CTraceback (most recent call last):
File "/home/franco/Desktop/SALOME-9.13.0-native-UB24.04-SRC/BINARIES-UB24.04/SALOME/bin/salome/salomeContext.py", line 747, in <module>
status = context._startSalome(args)
File "/home/franco/Desktop/SALOME-9.13.0-native-UB24.04-SRC/BINARIES-UB24.04/SALOME/bin/salome/salomeContext.py", line 328, in _startSalome
File "/home/franco/Desktop/SALOME-9.13.0-native-UB24.04-SRC/BINARIES-UB24.04/SALOME/bin/salome/salomeContext.py", line 419, in _sessionless
runSalome.runSalome()
File "/home/franco/Desktop/SALOME-9.13.0-native-UB24.04-SRC/BINARIES-UB24.04/KERNEL/bin/salome/runSalome.py", line 338, in runSalome
foreGround(args, ior_fakens_filename)
File "/home/franco/Desktop/SALOME-9.13.0-native-UB24.04-SRC/BINARIES-UB24.04/KERNEL/bin/salome/runSalome.py", line 252, in foreGround
sleep(dt)
KeyboardInterrupt
File "/home/franco/Desktop/SALOME-9.13.0-native-UB24.04-SRC/./mesa_salome", line 1075, in <module>
main(args)
File "/home/franco/Desktop/SALOME-9.13.0-native-UB24.04-SRC/./mesa_salome", line 1064, in main
out, err, status = context.runSalome(args)
File "/home/franco/Desktop/SALOME-9.13.0-native-UB24.04-SRC/BINARIES-UB24.04/KERNEL/bin/salome/salomeContext.py", line 151, in runSalome
out, err = proc.communicate()
File "/usr/lib/python3.12/subprocess.py", line 1201, in communicate
self.wait()
File "/usr/lib/python3.12/subprocess.py", line 1264, in wait
return self._wait(timeout=timeout)
File "/usr/lib/python3.12/subprocess.py", line 2053, in _wait
(pid, sts) = self._try_wait(0)
File "/usr/lib/python3.12/subprocess.py", line 2011, in _try_wait
(pid, sts) = os.waitpid(self.pid, wait_flags)
KeyboardInterrupt
HI Franco,
sorry for the late reply. Here, since you’re using the universal binary, you need to use run_salome.sh to ensure that you bootstrap SALOME with the embedded python, since the one of UB24 is not compatible
You can also run SALOME 9.13 built for Ubuntu 24
Hi all,
I’m new to Salome and tried to install several versions to use them in Ubuntu 22.04, but none of them run.
For version 9.11.0 I checked my native prerequisites with the command
./sat config SALOME-9.11.0-native --check_system
and it showed following lines:
File “/home/jspreng/SALOME-9.11.0/sat/./sat”, line 43, in
import src.logger as LOG
File “/home/jspreng/SALOME-9.11.0/sat/src/init.py”, line 43, in
from . import test_module
File “/home/jspreng/SALOME-9.11.0/sat/src/test_module.py”, line 33, in
import imp
ModuleNotFoundError: No module named ‘imp’
When I try running salome with ./salome, following lines appear:
What can I do to get Salome running correctly on my laptop?
Thank you very much for your answers.
Is there a particular reason to use version 9.11 ? IMHO, you should move to a more recent version and benefit from bug fixes and a one embedded script which fixes the reported issue.
In case you need to stick to that version, you can use the attached file to bootstrap the embedded python as follows:
mv run_salome.sh.txt SALOME-9.11.0/run_salome.sh
chmod u+x SALOME-9.11.0/run_salome.sh
SALOME-9.11.0/run_salome.sh # run --usage to see options
this script is part of more recent releases.
File: run_salome.sh.txt (1.6 KB)
Thank you very much for your answer!
Using your .txt file in combination with the command
chmod u+x SALOME-9.11.0/run_salome.sh.txt
the starting screen of Salome opens for a few seconds, but afterwards the GUI isnt popping up.
No, there is no reason for me to run 9.11. I just had the problem that 9.13 also did not work and so I tried another version. WIth 9.11 I got further with the installation, but still problems describes as above occurred…
I will try installing and running 9.13 with your tips and update my post after trying out if 9.13 works with that.
Do you have any opinions on the lines showed after running ./sat config SALOME-9.11.0-native --check_system ?
here since you’re using the universal binary, you do not need to run the command :
This command is aimed to check for some system prerequisites if you use one Ubuntu 22.04 SALOME release only.
Can you try instead to check whether running mesa layer helps, namely, run:
SALOME-9.11.0/run_salome.sh --mesa
If it does not help, you can check whether you’re running wayland for which some issues were reported in the past. You can check for instance output of: echo $XDG_SESSION_TYPE or ps -edf | grep X command and search for wayland. If this is the case, you can instead fall back to X11 (feasible usualy directly in the login screen).
See this thread or simply search for wayland in forum for additional informations.
Issues running Salome 9.12 on Debian 12 - Install & build - SALOME PROJECT
HTH.
It seems there is an issue with the version of Python you are using: “imp” and “SafeConfigParser” have been deprecated.
To fix “SafeConfigParser” see here
Thank you for the reply, I already solved the problem. ![]()
I believe, it will be useful to others if you could share how you resolved the second issue you reported about.
Thanks.
I solved the problem by installing salome with the Windows10.exe files on the salome download page.
