Installation problem with SALOME-9.9.0-UB18.04-SRC
Hi, I run ubuntu 18.04. I downloaded SALOME-9.9.0-UB18.04-SRC.tar.gz and extracted it to /opt/Salome9_9 and then tried to launch:
tar xfz SALOME-9.9.0-UB18.04-SRC.tar.gz
/opt/Salome9_9/SALOME-9.9.0-UB18.04-SRC/salome
I then get the error:
SALOME_Session_Server_No_Server: error while loading shared libraries: libgeos_c.so.1: cannot open shared object file: No such file or directory
I assume I have some missing PREREQUISITES. I then tried to find out what was missing with:
sat config SALOME-9.9.0 --check_system
Failed to import the site module
File “/opt/Salome9_9/SALOME-9.9.0-UB18.04-SRC/BINARIES-UB18.04/C3PO/lib/python3.6/site-packages/site.py”, line 73, in
__boot()
File “/opt/Salome9_9/SALOME-9.9.0-UB18.04-SRC/BINARIES-UB18.04/C3PO/lib/python3.6/site-packages/site.py”, line 22, in __boot
loader.load_module('site')
File “/opt/Salome9_9/SALOME-9.9.0-UB18.04-SRC/BINARIES-UB18.04/Python/lib/python3.6/site.py”, line 544, in
main()
File “/opt/Salome9_9/SALOME-9.9.0-UB18.04-SRC/BINARIES-UB18.04/Python/lib/python3.6/site.py”, line 530, in main
known_paths = addusersitepackages(known_paths)
File “/opt/Salome9_9/SALOME-9.9.0-UB18.04-SRC/BINARIES-UB18.04/Python/lib/python3.6/site.py”, line 282, in addusersitepackages
user_site = getusersitepackages()
File “/opt/Salome9_9/SALOME-9.9.0-UB18.04-SRC/BINARIES-UB18.04/Python/lib/python3.6/site.py”, line 258, in getusersitepackages
user_base = getuserbase() # this will also set USER_BASE
File “/opt/Salome9_9/SALOME-9.9.0-UB18.04-SRC/BINARIES-UB18.04/Python/lib/python3.6/site.py”, line 248, in getuserbase
USER_BASE = get_config_var('userbase')
File “/opt/Salome9_9/SALOME-9.9.0-UB18.04-SRC/BINARIES-UB18.04/Python/lib/python3.6/sysconfig.py”, line 601, in get_config_var
return get_config_vars().get(name)
File “/opt/Salome9_9/SALOME-9.9.0-UB18.04-SRC/BINARIES-UB18.04/Python/lib/python3.6/sysconfig.py”, line 550, in get_config_vars
_init_posix(_CONFIG_VARS)
File “/opt/Salome9_9/SALOME-9.9.0-UB18.04-SRC/BINARIES-UB18.04/Python/lib/python3.6/sysconfig.py”, line 421, in _init_posix
_temp = __import__(name, globals(), locals(), ['build_time_vars'], 0)
ModuleNotFoundError: No module named ‘_sysconfigdata_m_linux_x86_64-linux-gnu’
What can I do next? should I install libgeos-dev and hope that that resolves my issue? or is there a more instrumental approach to troubleshoot this?
BR/Micke
can you try first to install libgeos-c1v5 and try to run SALOME again ?
apt-file find /usr/lib/x86_64-linux-gnu/libgeos_c.so.1
libgeos-c1v5: /usr/lib/x86_64-linux-gnu/libgeos_c.so.1
apt install libgeos-c1v5
OK, thank you, installing libgeos-c1v5 seem to have solved the problem.
BR/Micke
