Installation problem with SALOME-9.9.0-native-UB20.04-SRC
hello ,
the Ubuntu 20 native version of Salome 9.9 does not run on my Ubuntu 20. This is the message in the linux shell:
johannes@lap2:~/work/22_Sie$ SA99
File “/opt/SALOME-9.9.0-native-UB20.04-SRC/BINARIES-UB20.04/SALOME/bin/salome/salomeContext.py”, line 281, in _startSalome
File “/opt/SALOME-9.9.0-native-UB20.04-SRC/BINARIES-UB20.04/SALOME/bin/salome/salomeContext.py”, line 368, in _sessionless
import setenv
File “/opt/SALOME-9.9.0-native-UB20.04-SRC/BINARIES-UB20.04/KERNEL/bin/salome/setenv.py”, line 26, in
import orbmodule
File “/opt/SALOME-9.9.0-native-UB20.04-SRC/BINARIES-UB20.04/KERNEL/bin/salome/orbmodule.py”, line 30, in
from nameserver import NamingServer
File “/opt/SALOME-9.9.0-native-UB20.04-SRC/BINARIES-UB20.04/KERNEL/bin/salome/nameserver.py”, line 26, in
from server import Server
File “/opt/SALOME-9.9.0-native-UB20.04-SRC/BINARIES-UB20.04/KERNEL/bin/salome/server.py”, line 25, in
from salome_utils import getHostName
File “/opt/SALOME-9.9.0-native-UB20.04-SRC/BINARIES-UB20.04/KERNEL/bin/salome/salome_utils.py”, line 39, in
import psutil
ModuleNotFoundError: No module named ‘psutil’
Strangly the file ‘psutil’ exists:
johannes@lap2:/opt/SALOME-9.9.0-native-UB20.04-SRC$ find -type f -name ‘psutil.py’
./PROJECT/products/env_scripts/psutil.py
Even when changing to the directory which contains ‘psutil.py’ this problem appears.
How can this be resolved?
many thanks
Johannes_ACKVA
www.code-aster.de
You have some missing required system packages which need to be installed. Here, you need to install: python3-psutil
Check the README file to see how to get the list of system dependencies.
HTH.
thank you, it works fine now
Johannes_ACKVA
Hello, when I try to run ./sat config SALOME-9.9.0-native --check_system
it just says -bash: ./sat: Is a directory
what is wrong?
Hi Jacob,
sat is in the sat directory, so type:
sat/sat config SALOME-9.9.0-native --check_system
