I have an STL file that was generated using Rhino7. I succeeded in importing the file into Salome (Shaper), and I transferred it to the (geometry) module, but I am not able to define groups in this model. When the dialogue of creating groups is displayed, I cannot select the model in the text field (Main shape). How can I define groups of such a model in Salome? thanks for your help
Can you provide the stl file , so we could take a closer look?
Mohamed
First, note that you can import STL directly in GEOM, no need to do it in SHAPER.
Then I tried your steps on 9.12 Windows, and Debian 10 with no issues.
How do you create the group?
The main shape need to be selected under the GEOM node, the exported one, not the imported node from ShaperResults.
You can try with the context menu “Create Group” it will set the field automatically.
