Importing geometry from CAD to SALOME
I am having a problem with import geometry to SALOME. I need to import a CAD file (dxf, dwg, etc.) but the program reads only BREP, XAO, IGES, STL or STEP. Is there a way to convert a dxf/dwg to a supported file format or to just read it in SALOME without converting?
The files I need to import are 2D geometry so maybe there is also a way to export it from CAD to a supported file format?
Matt =]]
I understand there is a SHAPER DXF plugin that allows for importing CAD files in that format, but it does not seem to be publicly available. Maybe @fred can comment further.
