Importing Fine STL Mesh into Salome for Meshing
Greetings everyone,
I hope this message finds you all well. I am currently facing an issue while working with puma to create an STL file. My goal is to import this STL mesh into Salome for meshing purposes. However, I am encountering difficulty due to the fine nature of the mesh, making it challenging to manipulate in Salome.
I kindly request your assistance and guidance regarding a possible solution to make the STL mesh coarser within Salome. By doing so, I believe it will allow for easier manipulation within the software.
I truly appreciate any insights, suggestions, or advice you can provide. Thank you very much in advance for sharing your expertise and support.
