I’ve noticed small accuracy issues when importing STEP files into SALOME—for example, a 1000 mm dimension imports as about 999.9999 mm. I have tried reducing the B-spline tolerance during export from NX, but it didn’t improve the accuracy.
Will SALOME consider adding support for direct Parasolid (.x_t) import? This could help keep better accuracy.
Also, any advice on how to reduce accuracy loss when importing STEP files would be appreciated.
