Hello, dear Salome community.
I am trying to install Salome on Linux Mint (which is based on Ubuntu v24). As per the instructions, I downloaded the archive, extracted it to a folder, navigated to that folder in the terminal and ran the following command: ./sat/sat config SALOME-9.15.0-native --check_system. The output of this command is the following: /usr/bin/env: ‘python’: No such file or directory.
My question is whether the provided output is the dependency that ./sat/sat tells me I am missing for Salome to run, or it is an error that tells me that I cannot run ./sat/sat because I don’t have Python installed.
In the latter case, what Python version do I need to install for ./sat/sat to run?
Thank you in advance.
Ivan
