I’d like to mesh a component using hexahedral elements. It consists of two parts - pin and spring. It’s shown in the attached picture:
I used Explode → Solid to get separate components. Then I defined two groups - with one edge of the pin and with one edge of the spring (to control the number of elements). I’d like to obtain extruded hex mesh with 1 element in the thickness direction. However, I don’t know exactly how to do it in Salome. I defined two meshes (for each part) with the following settings:
- 3D: Extrusion 3D
- 1D: Wire discretisation:
Number of segments: 15
Quadratic Mesh
and two submeshes (for each edge):
Quadratic Mesh
Unfortunately, I can’t generate correct meshes this way. Maybe I should define the starting face and extrusion direction somehow? Or use a different algorithm?
I attached the .hdf and .step files below:
Meshing.hdf (1004,6 KB)
Leaf spring v3 with pin - no separate leaves_eye_gap.step (64,0 KB)
