How to delete a solid
Hi, How do I delete a solid in shaper?
Sometimes you can right click on the Result and choose delete but that is not always possible (delete button not active). For such case how do I delete the solid that I do not want? In my case it is a imported step model with some parts that I do not want. I have used some of the solid geometry as reference curves and may be that is why it is not possible to delete it. Still I hope there is a way to get rid of unwanted result solids that you do not want any more…is it possible?
BR/Micke
you can use the feaure remove sub-shapes to remove solids of a compound or a compsolid. Either select the solids you want to remove (1st icon) or those you want to keep (2nd icon).
