Hi,
if you want to debug your module (other modules can stay in release mode):
- start SALOME,
- retrieve the pid of process
SALOME_Session* - start gdb or any other debugger gui (e.g.
gdbguiorQtCreator) - in your gdb session attach to the process.
Note that you need to ensure that process tracking is enabled:
cat /proc/sys/kernel/yama/ptrace_scope
should return 0
More generally if you want to develop within SALOME, here is the approach you could use - I use it but other more advanced SALOME users may provide some additional tips/tricks.
This is illustrated below for Ubuntu 22.
Note that for Windows, you need to compile every module in debug with SAT, setting debug to yes in SALOME-9.12.0-windows.pyconf
# 0- Extract SALOME archive
tar zxf SALOME-9.12.0-native-UB22.04-SRC.tar.gz
cd SALOME-9.12.0-native-UB22.04-SRC
# 1- setup the developer mode
chmod u+x install_bin.sh
./install_bin.sh
# 2- generate a launcher which will use INSTALL directory instead of BINARIES-UB22.04
sat/sat launcher SALOME-9.12.0-native -n salome
# 3- generate a setup script aimed to set SALOME build and runtime environments
sat/sat environ SALOME-9.12.0-native
# 4- setup SALOME developer environment
source SALOME-9.12.0-native-UB22.04-SRC/env_build.sh
# 5- Prepare your sources and compile in DEBUG mode - step 4 ensures that relevant environment variables are set.
# Here you can iterate (make, make install)
# 6- edit file salome and append to it your module (see how this is done with HELLO)
