I have created my custom C++ module using HELLO project as a template.
I am able to build it in both Release and Debug configurations.
Also, I discovered how to load it into SALOME, so everything is fine in Release mode. My module works as expected.
And my question is: how to debug the code of my module?
SALOME crashes if only my module is built in DEBUG mode when I try to switch to the module in already started SALOME.
After that, I had tried to build KERNEL and GUI in debug mode, it looks like I succussed with this, but now SALOME crashes at start-up time. I do not see the exception information under the logo)). But I think that it is caused by Release/Debug mix of run-time libraries.
What is the correct approach to develop (debug) custom modules in SALOME world?
if you want to debug your module (other modules can stay in release mode):
start SALOME,
retrieve the pid of process SALOME_Session*
start gdb or any other debugger gui (e.g. gdbgui or QtCreator)
in your gdb session attach to the process.
Note that you need to ensure that process tracking is enabled: cat /proc/sys/kernel/yama/ptrace_scope
should return 0
More generally if you want to develop within SALOME, here is the approach you could use - I use it but other more advanced SALOME users may provide some additional tips/tricks.
This is illustrated below for Ubuntu 22.
Note that for Windows, you need to compile every module in debug with SAT, setting debug to yes in SALOME-9.12.0-windows.pyconf
# 0- Extract SALOME archive
tar zxf SALOME-9.12.0-native-UB22.04-SRC.tar.gz
cd SALOME-9.12.0-native-UB22.04-SRC
# 1- setup the developer mode
chmod u+x install_bin.sh
./install_bin.sh
# 2- generate a launcher which will use INSTALL directory instead of BINARIES-UB22.04
sat/sat launcher SALOME-9.12.0-native -n salome
# 3- generate a setup script aimed to set SALOME build and runtime environments
sat/sat environ SALOME-9.12.0-native
# 4- setup SALOME developer environment
source SALOME-9.12.0-native-UB22.04-SRC/env_build.sh
# 5- Prepare your sources and compile in DEBUG mode - step 4 ensures that relevant environment variables are set.
# Here you can iterate (make, make install)
# 6- edit file salome and append to it your module (see how this is done with HELLO)
To build SALOME with SAT, repeat steps 0-3. described in my previous reply.
Then, you need to apply the following prescription. Assuming that your module is named MYHELLO, you need to:
Describe your module in the SAT syntax, namely:
create a python description file PROJECT/products/MYHELLO.pyconf
Since SAT implements a DAG, ensure that all dependencies are set in key: depends.
if MYHELLO compilation requires some advanced approach, implement a script in products/compil_scripts/MYHELLO.sh or products/compil_scripts/MYHELLO.bat
Note that you do have access to some environment variables which are set by SAT: (BUILD_DIR, PRODUCT_INSTALL, SOURCE_DIR, etc…) - look at some scripts
define all runtime environment variables in PROJECT/products/MYHELLO.pyconf (section environ)
add MYHELLO to PROJECT/applications/SALOME-9.12.0-{native,windows}.pyconf
Then,
extract the sources of your project (or module) to SOURCES/MYHELLO
you can then compile with : sat/sat compile SALOME-9.12.0-native -p MYHELLO --clean_all
Logs files, if any will be saved in LOGS/MYHELLO/{cmake, make, makeinstall, script}
But again, if you want to be efficient , better use first approach described in my first reply.
