how can i change salome theme from light mode to dark mode,as fast you can
To change theme, on linux, run qt5ct command line. In the window which pops up, set style to Fusion and Pallet to Darker.
Then simply set this environment variable:
export QT_QPA_PLATFORMTHEME=qt5ct
and run SALOME.
On Windows, you need to activate the dark mode.
