as described in: issue the cleanning process (merging all the blocks) of a cut geometry in geom is giving me issues (ie., wrong geometry).
momentarilly i made a function to clean up the blocked geometry by fusing one by one the objects and cleaning after fusing them.
this works until a specific block of the compound, where it freezes salome completly (see first comment on the issue i mentionned before). it is freezing at a super simple geometry therefore i am seeking some insight to solve this limitation.
in the other CAD softwares i have on hand (freecadv1.0.1, onshape) the boolean option works correctly (select all, boolean and it will succed in obtain the solid without internal faces or extra edges.
@cbourcier opinions on this? it looks like it is a clear issue with the boolean operation.
