FileNotFoundError: [WinError 2] The system cannot find the file specified
I have been unable to start the application, it seems that I am lacking the file: runConsole.py
PS E:\SALOME> python salome start -gk
runSalome running on Someones-Laptop
Searching for a free port for naming service: 2816 - OK
th. 00000033A574FA90 - Trace e:\s\salome-9.8.0\sources\kernel\src\namingservice\salome_namingservice.cxx [1351] : CORBA::SystemException: unable to contact the naming service
  File "E:\SALOME\W64\KERNEL\bin\salome\runSalome.py", line 694, in useSalome
    clt = startSalome(args, modules_list, modules_root_dir)
  File "E:\SALOME\W64\KERNEL\bin\salome\runSalome.py", line 482, in startSalome
    clt=orbmodule.client(args)
  File "E:\SALOME\W64\KERNEL\bin\salome\orbmodule.py", line 56, in __init__
    self.initNS(args or {})
  File "E:\SALOME\W64\KERNEL\bin\salome\orbmodule.py", line 76, in initNS
    NamingServer(args).run()
  File "E:\SALOME\W64\KERNEL\bin\salome\server.py", line 80, in run
    pid = subprocess.Popen(command).pid
  File "E:\SALOME\W64\Python\lib\subprocess.py", line 709, in __init__
    restore_signals, start_new_session)
  File "E:\SALOME\W64\Python\lib\subprocess.py", line 997, in _execute_child
    startupinfo)
--- Error during Salome launch ---
And then when I do:
E:\SALOME>python salome connect -p 2816
Search for running instance on port 2816...
   ...found unique instance: AaronEJs-Laptop:2816
Selected instance: AaronEJs-Laptop:2816
python3: can't open file 'E:\SALOME\W64\SALOME\bin\salome\runConsole.py': [Errno 2] No such file or directory
to start SALOME on windows, simply use run_salome.bat or run_salome.exe scripts. Can you try these approaches to check?
Thanks
Hello
Try ré installing it, and pay extra attention to you anti-virus, avast deleted several files while installing v9.8
Oh, that was the first thing I did, using the command line was just so that I could do diagnostics and not have the console disappear. The error is the same though.
Thanks, that must have been it. Uninstalling and reinstalling with Avast disabled did the trick, even though Avast made no mention that it was blocking anything.
