Error during Salome launch on Fedora 35 desktop
I downloaded the Fedora 34 package of Salome 9.8.0 and since it is not compatible with Fedora 35 which I use I started a compilation of all the software components. After building / installing all requirements I tried to run Salome but I get the following error:
runSalome running on reynolds
Searching for a free port for naming service: 2820 - OK
Searching Naming Service  + found in 0.1 seconds
Searching /Kernel/Session in Naming Service  +Warning, no type found for resource "localhost", using default value "single_machine"
++Traceback (most recent call last):
  File "/home/panos/Development/Salome/SALOME-9.8.0/INSTALL/KERNEL/bin/salome/orbmodule.py", line 181, in waitNSPID
    os.kill(thePID,0)
ProcessLookupError: [Errno 3] No such process
  File "/home/panos/Development/Salome/SALOME-9.8.0/INSTALL/KERNEL/bin/salome/runSalome.py", line 694, in useSalome
    clt = startSalome(args, modules_list, modules_root_dir)
  File "/home/panos/Development/Salome/SALOME-9.8.0/INSTALL/KERNEL/bin/salome/runSalome.py", line 639, in startSalome
    session=clt.waitNSPID("/Kernel/Session",mySessionServ.PID,SALOME.Session)
  File "/home/panos/Development/Salome/SALOME-9.8.0/INSTALL/KERNEL/bin/salome/orbmodule.py", line 183, in waitNSPID
    raise RuntimeError("Process %d for %s not found" % (thePID,theName))
RuntimeError: Process 43380 for /Kernel/Session not found
--- Error during Salome launch ---
I have the relevant system log at the end of this message.
Using the command:
./sat config SALOME-9.8.0-native --check_system
produced a green list, no problems. I also tried to run ParaView as suggested in another thread:
salome context
paraview
And this indeed launched ParaView without any problems.
Any ideas on how to resolve this problem?
Log:
System log file
just to ensure that we narrow down the issue, can you try the following:
  • run salome sessionless to check if it runs without Corba
  • if running without Corba helps to solve the issue, then can you share your /etc/hostname file, such that we can investigate further and discuss this recurrent issue.
  • if running in sessionless mode still shows an issue, then try the universal binary.
HTH
I don’t know how to run it in this mode. When I run
./salome --sessionless
I get an error message that it does not recognise this option.
usage: salome start [options] [STUDY_FILE] [PYTHON_FILE [args] [PYTHON_FILE [args]...]]
Python file arguments, if any, must be comma-separated (without blank characters) and prefixed by "args:" (without quotes), e.g. myscript.py args:arg1,arg2=val,...
runSalome: error: unrecognized arguments: --sessionless
ERROR:salomeContext:SystemExit 2 in method _runAppli
sorry was a typo… use:
salome sessionless
It does nothing. I press Enter and then it executes the script and nothing happens.
this is strange. Alternatively you can do:
export SALOME_EMB_SERVANT=1 && ./salome
if still it does not help, you need to try with the universal binary to see if this helps.
An additional question: how did you compile SALOME on your Fedora 35 ?
Thanks
This command does exactly the same thing as running the application directly. The same error message. The universal version works fine but I would like to be able to also compile Code_Saturne with Salome support and that does not work with the universal version which is compiled on CentOS 7.
Regarding the compilation process on Fedora 35, I downloaded the Fedora 34 version and then I used sat:
./sat prepare SALOME-9.8.0-native
./sat compile SALOME-9.8.0-native
I encountered some small issues with the PYQT_SIPS_DIR which was not detected so I manually set it to the appropriate path on my system on some .pyconf files.
cmake_options : '-DPYQT_SIPS_DIR=/usr/lib64/python3.10/site-packages/PyQt5/bindings'
and then I managed to compile all the packages.
one last thing you can try:
./sat launcher SALOME-9.8.0-native
./salome context
./INSTALL/GUI/bin/salome/salome2810
I did that but again nothing happened. I had no message on the screen but my computer’s log had this error:
Stack trace of thread 79031:
#0  0x00007fc501e8b88c __pthread_kill_implementation (libc.so.6 + 0x8f88c)
#1  0x00007fc501e3e6a6 raise (libc.so.6 + 0x426a6)
#2  0x00007fc501e287d3 abort (libc.so.6 + 0x2c7d3)
#3  0x00007fc50805e44b _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0xb144b)
#4  0x00007fc50869d41c _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x16341c)
#5  0x00007fc50869d8a8 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x1638a8)
#6  0x00007fc50825a493 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x2ad493)
#7  0x00007fc50869fca0 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x165ca0)
#8  0x00007fc508d2d9fd _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x1b39fd)
#9  0x000000000040974e n/a (/home/panos/Development/Salome/SALOME-9.8.0/INSTALL/GUI/bin/salome/SALOME_Session_Server_No_Server + 0x974e)
#10 0x00007fc501e29560 __libc_start_call_main (libc.so.6 + 0x2d560)
#11 0x00007fc501e2960c __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d60c)
#12 0x0000000000407e95 n/a (/home/panos/Development/Salome/SALOME-9.8.0/INSTALL/GUI/bin/salome/SALOME_Session_Server_No_Server + 0x7e95)
It looks like there is a problem with the GUI module.
When configuring the GUI module with sat I get the following:
./sat -t compile SALOME-9.8.0-native -f -p GUI                      ✔  17:11:42
Executing the compile commands in the build directories of the products of the application SALOME-9.8.0-native
  SOURCE directory = /home/panos/Development/Salome/SALOME-9.8.0/salomeTools/../SOURCES
   BUILD directory = /home/panos/Development/Salome/SALOME-9.8.0/salomeTools/../BUILD
Compilation of GUI ........................... CONFIGURE  build_dir   = /home/panos/Development/Salome/SALOME-9.8.0/salomeTools/../BUILD/GUI
  install_dir = /home/panos/Development/Salome/SALOME-9.8.0/salomeTools/../INSTALL/GUI
  CFLAGS = -march=native -fPIC
> cmake  -DSWIG_EXECUTABLE=${SWIG_ROOT_DIR}/bin/swig -DPYQT_SIPS_DIR=/usr/lib64/python3.10/site-packages/PyQt5/bindings -DSALOME_CMAKE_DEBUG=ON -DOpenGL_GL_PREFERENCE=GLVND  -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/home/panos/Development/Salome/SALOME-9.8.0/salomeTools/../INSTALL/GUI /home/panos/Development/Salome/SALOME-9.8.0/salomeTools/../SOURCES/GUI
CMake Deprecation Warning at CMakeLists.txt:19 (CMAKE_MINIMUM_REQUIRED):
  Compatibility with CMake < 2.8.12 will be removed from a future version of
  CMake.
  Update the VERSION argument <min> value or use a ...<max> suffix to tell
  CMake that the project does not need compatibility with older versions.
-- The C compiler identification is GNU 11.2.1
-- The CXX compiler identification is GNU 11.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/lib64/ccache/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/lib64/ccache/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Building SALOMEGUI 9.8.0 from "unknown"
-- Looking for Salome KERNEL ...
-- ===> Reloading targets from LibBatch ...
-- ===> Reloading targets from HDF5 ...
-- Found Salome KERNEL: /home/panos/Development/Salome/SALOME-9.8.0/salomeTools/../INSTALL/KERNEL
-- Performing Test COMPILER_SUPPORTS_NO_OPERATOR_NAMES
-- Performing Test COMPILER_SUPPORTS_NO_OPERATOR_NAMES - Success
-- Setting C++ standard to 11
-- Setting PYTHONINTERP_ROOT_DIR to: /usr
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.10.2", minimum required is "3")
-- Setting PYTHONLIBS_ROOT_DIR to: /usr
-- Found PythonLibs: /usr/lib64/libpython3.10.so (found suitable version "3.10.2", minimum required is "3.10.2")
-- Python libs and interpreter versions are matching: 3.10.2
-- Looking for PThread...
-- Found PThread: /usr/include
-- PThread library: /usr/lib64/libpthread.so
-- Variable PTHREAD_ROOT_DIR was not explicitly defined. An installation was found anyway: /usr
-- PThread directory matches what was previously exposed by another prereq, all good!
-- Found SWIG: /usr/bin/swig (found version "4.0.2")
-- SWIG found directory matches what was specified in the SWIG_ROOT_DIR variable, all good!
-- SWIG directory matches what was previously exposed by another prereq, all good!
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Found Boost: /usr/include (found version "1.76.0") found components: filesystem regex system thread date_time chrono serialization atomic
-- Boost found directory matches what was specified in the BOOST_ROOT_DIR variable, all good!
-- Boost include dirs is: /usr/include
-- Found HDF5: hdf5::hdf5-shared (found version "1.10.3")
-- Found OmniORB: /usr/include (found version "4.2.4")
-- OmniORB found directory matches what was specified in the OMNIORB_ROOT_DIR variable, all good!
-- OmniORB directory matches what was previously exposed by another prereq, all good!
-- Found OmniORBPy: /usr/lib/python3.10/site-packages/omniidl_be
-- OmniORBPy found directory matches what was specified in the OMNIORBPY_ROOT_DIR variable, all good!
-- OmniORBPy directory matches what was previously exposed by another prereq, all good!
-- Looking for CppUnit ...
-- Checking for one of the modules 'cppunit'
-- Found CppUnit: /usr/include
-- CppUnit found directory matches what was specified in the CPPUNIT_ROOT_DIR variable, all good!
-- CppUnit directory matches what was previously exposed by another prereq, all good!
-- Found Doxygen: /usr/bin/doxygen (found version "1.9.1") found components: doxygen dot
-- Doxygen found directory matches what was specified in the DOXYGEN_ROOT_DIR variable, all good!
-- Doxygen directory matches what was previously exposed by another prereq, all good!
-- Found Graphviz: /usr/bin/dot
-- Graphviz found directory matches what was specified in the GRAPHVIZ_ROOT_DIR variable, all good!
-- Graphviz directory matches what was previously exposed by another prereq, all good!
-- Found Sphinx: /usr/bin/sphinx-build
-- Found Sphinx version 4.1.2
-- Sphinx found directory matches what was specified in the SPHINX_ROOT_DIR variable, all good!
-- Sphinx directory matches what was previously exposed by another prereq, all good!
-- Looking for SIP ...
-- Found SIP: /usr/include/python3.10
-- SIP found directory matches what was specified in the SIP_ROOT_DIR variable, all good!
-- Found OpenCASCADE in CONFIG mode!
-- OpenCASCADE found directory matches what was specified in the OPENCASCADE_ROOT_DIR variable, all good!
-- Found OpenCascade version: 7.5.3
-- Found OpenGL: /usr/lib64/libOpenGL.so
-- Variable OPENGL_ROOT_DIR was not explicitly defined. An installation was found anyway: /usr
-- Qt version is 5.15.2
-- Found SIP in CONFIG mode!
-- Looking for PyQt5 ...
-- Found PyQt5: /usr/bin/pyuic5
-- PyQt5 found directory matches what was specified in the PYQT5_ROOT_DIR variable, all good!
-- Found Embree v3.12.2: /home/panos/Development/Salome/SALOME-9.8.0/INSTALL/embree/lib/libembree3.so.3.12.2
-- Found Open VKL v0.11.0: /home/panos/Development/Salome/SALOME-9.8.0/INSTALL/openVKL/lib/libopenvkl.so.0.11.0
-- Found ParaView in CONFIG mode!
-- ParaView found directory matches what was specified in the PARAVIEW_ROOT_DIR variable, all good!
-- Looking for VTK in the ParaView installation (PARAVIEW_ROOT_DIR exists and VTK_ROOT_DIR is not defined) ...
-- Setting VTK_DIR to: /home/panos/Development/Salome/SALOME-9.8.0/INSTALL/ParaView/lib/cmake/paraview-5.9/vtk
-- Found VTK in CONFIG mode!
-- VTK found directory matches what was specified in the VTK_ROOT_DIR variable, all good!
-- VTK version is 9.0
-- Looking for Qwt ...
-- Found Qwt: /usr/include/qt5/qwt
CMake Warning at /home/panos/Development/Salome/SALOME-9.8.0/SOURCES/CONFIGURATION/cmake/SalomeMacros.cmake:605 (MESSAGE):
  Qwt was found, but not at the path given by the environment QWT_ROOT_DIR!
  Is the variable correctly set? The two paths are: /usr/include/qt5 and:
  /usr
Call Stack (most recent call first):
  /home/panos/Development/Salome/SALOME-9.8.0/SOURCES/CONFIGURATION/cmake/FindSalomeQwt.cmake:26 (SALOME_FIND_PACKAGE_AND_DETECT_CONFLICTS)
  CMakeLists.txt:203 (FIND_PACKAGE)
--   Optional packages - Detection report
--   * CppUnit                  ->  Found
--   * Doxygen                  ->  Found
--   * Graphviz                 ->  Found
--   * Sphinx                   ->  Found
--   * ParaView                 ->  Found
--   * VTK                      ->  Found
--   * Qwt                      ->  Found
-- Creation of /home/panos/Development/Salome/SALOME-9.8.0/BUILD/GUI/src/GUI_PY/qtsalome.py
-- Creation of /home/panos/Development/Salome/SALOME-9.8.0/BUILD/GUI/src/GUI_PY/__init__.py
CMake Warning (dev) at /usr/share/cmake/Modules/UseSWIG.cmake:775 (message):
  Policy CMP0078 is not set: UseSWIG generates standard target names.  Run
  "cmake --help-policy CMP0078" for policy details.  Use the cmake_policy
  command to set the policy and suppress this warning.
  src/PVServerService/ServiceLoader/CMakeLists.txt:65 (SWIG_ADD_LIBRARY)
This warning is for project developers.  Use -Wno-dev to suppress it.
CMake Warning (dev) at /usr/share/cmake/Modules/UseSWIG.cmake:617 (message):
  Policy CMP0086 is not set: UseSWIG honors SWIG_MODULE_NAME via -module
  flag.  Run "cmake --help-policy CMP0086" for policy details.  Use the
  cmake_policy command to set the policy and suppress this warning.
  /usr/share/cmake/Modules/UseSWIG.cmake:888 (SWIG_ADD_SOURCE_TO_MODULE)
  src/SALOME_SWIG/CMakeLists.txt:86 (SWIG_ADD_LIBRARY)
-- Creation of /home/panos/Development/Salome/SALOME-9.8.0/BUILD/GUI/doc/salome/tui/doxyfile
-- Creation of /home/panos/Development/Salome/SALOME-9.8.0/BUILD/GUI/doc/salome/tui/static/header.html
-- Creation of /home/panos/Development/Salome/SALOME-9.8.0/BUILD/GUI/doc/salome/gui/conf.py
-- Creation of /home/panos/Development/Salome/SALOME-9.8.0/BUILD/GUI/doc/salome/gui/static/switchers.js
-- Creation of /home/panos/Development/Salome/SALOME-9.8.0/BUILD/GUI/bin/VERSION
CMake Warning (dev) at tools/PyConsole/CMakeLists.txt:45 (OPTION):
  Policy CMP0077 is not set: option() honors normal variables.  Run "cmake
  --help-policy CMP0077" for policy details.  Use the cmake_policy command to
  For compatibility with older versions of CMake, option is clearing the
  normal variable 'BUILD_SHARED_LIBS'.
-- Found PythonInterp in CONFIG mode!
-- Found PythonLibs in CONFIG mode!
-- Found PyQt5 in CONFIG mode!
--   * VTK                      ->  Found
--   * Qwt                      ->  Found
--   * SalomeSIP                ->  Found
--   * SalomePyQt5              ->  Found
--   * VTK                      ->  Found
--   * Qwt                      ->  Found
CMake Deprecation Warning at tools/CurvePlot/CMakeLists.txt:19 (CMAKE_MINIMUM_REQUIRED):
  CMake.
-- NumPy found : /usr/lib64/python3.10/site-packages/numpy/core/include
-- Scipy found : Version 1.7.3
--   * VTK                      ->  Found
--   * Qwt                      ->  Found
-- Creation of /home/panos/Development/Salome/SALOME-9.8.0/BUILD/GUI/tools/CurvePlot/src/python/controller/utils.py
-- Creation of /home/panos/Development/Salome/SALOME-9.8.0/BUILD/GUI/tools/CurvePlot/src/python/controller/utils_test.py
-- Creation of /home/panos/Development/Salome/SALOME-9.8.0/BUILD/GUI/tools/CurvePlot/src/python/test/mockup/SalomePyQt_MockUp.py
--   * VTK                      ->  Found
--   * Qwt                      ->  Found
--   * SalomePythonInterp       ->  Found
--   * SalomePythonLibs         ->  Found
CMake Deprecation Warning at tools/RemoteFileBrowser/CMakeLists.txt:21 (CMAKE_MINIMUM_REQUIRED):
  CMake.
-- Creation of /home/panos/Development/Salome/SALOME-9.8.0/BUILD/GUI/GUI_version.h
-- Configuring done
I don’t see any problems.
I will try on my side to setup a Fedora 35 environment and see if I can reproduce your issue.
By the way, I don’t know if you did it already, but before running sat config SALOME-9.8.0-native --check_system command, you need of course to patch PROJECT/products/salome_system.pyconf which is missing some bits and nd add right after “FD34” section, a new section dedicated to FD35:
  FD35 :
    rpm :
      'lz4-libs'
      'gsl'
    rpm_dev :
      'lz4-devel'
      'qt5-qtbase-devel'
      'gsl-devel'
and ensure that these rpm system dependencies are installed.
Thank you. I have these packages already installed.
I found the problem. For some reason, GUI is trying to load Qt plugins from the GUI/bin/salome directory instead of the Qt system directory. This can be fixed by adding to the salome launcher script the line:
context.setVariable(r"QT_QPA_PLATFORM_PLUGIN_PATH", r"/lib64/qt5/plugins", overwrite=True)
Huh, that really saved my day. Thank you so much. I had familiar problem here in Ubuntu 22.04 (built from source using 9.8.0-native-UB20.04-SRC.tar.gz) and setting QT_QPA_PLATFORM_PLUGIN to the system directory solved the problem.
