I wanted to download SALOME 9.15 to install on ubuntu 22.04, in the link it only downloaded SALOME-9.15.0-native-UB22.04-SRC.tar.gz, is there any way to download the SALOME-9.15.0-native-UB22.04.tar.gz?
I tried to install SALOME-9.15.0-native-UB22.04-SRC.tar.gz
If you intend to use SALOME as it is, you do not need to run install_bin.sh , as that is only for setting up development mode. You only need to run the following command lines to ensure that all system prerequisites are installed:
Then launch SALOME : SALOME-9.15.0-native-UB22.04-SRC/salome
You can also use the universal binary, which includes all necessary prerequisites and which makes things more confortable. To launch SALOME, here you need to run:
SALOME-9.15.0/run_salome.sh
If you still want to run install_bin.sh, here are the command lines which I tested:
tar zxf SALOME-9.15.0-native-UB22.04-SRC.tar.gz
cd SALOME-9.15.0-native-UB22.04-SRC
./install_bin.sh
sat/sat launcher SALOME-9.15.0-native
One can also do (better):
mv SALOME-9.15.0-native-UB22.04-SRC SALOME-9.15.0-native-UB22.04
./install_bin.sh
cd ..
# clone SAT and SAT_SALOME
git clone https://github.com/SalomePlatform/sat.git SAT
git clone https://github.com/SalomePlatform/sat_salome.git SAT_SALOME
# expose SAT_SALOME to SAT
SAT/sat init --add_project $PWD/SAT_SALOME/salome.pyconf
# clone ALL SALOME products from GitHub
SAT/sat -o "APPLICATION.properties.git_server='github'" prepare SALOME-9.15.0-native --properties 'is_SALOME_product:yes'
# run a compilation of all SALOME products
SAT/sat -o "APPLICATION.properties.git_server='github'" compile SALOME-9.15.0-native --properties 'is_SALOME_product:yes' --clean_all
# in case you want to clone/compile SHAPER only
SAT/sat -o "APPLICATION.properties.git_server='github'" prepare SALOME-9.15.0-native -p CONFIGURATION,SHAPER
# compile SHAPER only
SAT/sat -o "APPLICATION.properties.git_server='github'" compile SALOME-9.15.0-native -p SHAPER --clean_all
# generate a launcher
SAT/sat launcher SALOME-9.15.0-native
# run SHAPER tests to check your implementation is consistent
SALOME-9.150-native-UB22.04/salome test -R SHAPER
# launch SALOME
SALOME-9.15.0-native-UB22.04/salome
You can also do everything from scratch by following the recipe at this link :
→ ./sat config SALOME-9.15.0-native --check_system
/usr/bin/env: «python»: does not exist
Python should be = python3
sudo apt install python-is-python3
./sat config SALOME-9.15.0-native --check > depend.txt
grep “KO” depend.txt
grep “KO” depend.txt > missing.txt
in this file, I had to leave the only the packages that are missing (that was manual work) I erased the text :
