I am re-activating the seemingly old problem of removing (deleting) geometrical objects via TUI.
I found some threads devoted to this on the old forum, and searched through the new forum, but the threads I found indicate that the issue is still (partially) open.
My motivation is the following: I have to create a script which
Generates a parametrised structure in Shaper, made of several faces
Export it to GEOM
3… and delete some of the redundant faces, knowing their location (extend + center of gravity)
The 1. and 2. tasks are feasible - my dumped python script behaves as expected. However, I do not know how to perform the third operation.
I found the following pieces of solution:
the example script on the old forum (forum_10/125393444#7275533), with deleteShape method
the PDF document “A short introduction to SHAPER” by Raphaël Marc, with a promising example including “model.selection(“FACE”, (5, 5, 5)”, which probably performs the needed selection-by-location
the new forum thread Selection of edges, vertex, faces of solid in shaper TUI
with interesting explanations
- the “stub” of documentation concerning the geomtools, on salome doccumentation platform
It seems, that the required functions are there, but the documentation is almost entirely missing. Will it be provided in some near future?
I will be grateful for help, and I shall share my solution, if I find one.
Regards
Marek
